Question about Whirlpool WTW5300SQ Top Load Washer
Washer is vibrating bad,leveled and stiil vibrates.
  • Whirlpool Master
  • 5,568 Answers
The outer tub is suspended by either heavy rubber bands or springs. One of these may be loose or broken.
You should be able to see them by removing the lower rear panel but if not, check on the Sears link below to see if they have your machine in their library. If they do, there will be an exploded line illustration of your machine that will show these points.
If they have it, you can also order parts through them if available.
Sears parts department
Posted on Jan 01, 2011
Vibrates real bad in spin mode.
Check to see if the washer is level, and adjust the leveling legs if necessary. Always lock the legs in place after adjustment to keep them from getting loose as they do work themselves loose during heavy vibration conditions.
The following items could cause the vibration problem:
1. Clutch assembly
2. Vibration dampers that support the tub. Should one or more be faulty, always replace all four simultaneously.
Feb 24, 2016 | LG WFT1071TP Top Load Washer
Bad vibration when washer is spinning.
If the washer is vibrating, it's not sitting solidly on the floor. Move it until it sits solidly. If needed, adjust the leveling legs. It might also vibrate if the shipping blocks and bolts weren't removed when the washer was installed, or the wash load isn't distributed evenly.
If all this looks good, check the shock absorber to see if one has broken.
Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Spin cycle massive vibration everytime. Size of load doesn't matter?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
How to keep the floor from vibrating while in spin cycle
Most likely cause of vibration is that the washer isn't leveled. Use a torpedo or carpenters level and adjust the support feet on the washer to get it level. If it still makes the floor vibrate, you may have a soft floor. You could then try putting a piece of 3/4 plywood under the washer to help support the weight.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is vibrating even after leveling the washer
if fornt load look at the shocks . as one may be broken / most common . and don't forget after leveling ( LOCK THE LEGS ) the no/ no 's are legs too high an not locked . and no rubber feet . . and sometimes just bad floors. ****
Jan 02, 2010 | Washing Machines
Washer vibrating badly
Hi, Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion......
Jul 19, 2009 | LG Washing Machines
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool WTW5300SQ Top Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
