Question about Bissell 6594 PowerForce Bagless Upright Vacuum
What do i do if my vacuum can't **** in some things such as dog hair?
  • 694 Answers
Make sure the brush bristles extend past the brush opening on the power head. If they don't, brush replacement is necessary.
Posted on Jan 01, 2011
VacuumRepair
  • 438 Answers
SOURCE: Bissel Cleanview II (bagless 12 amp)
Greetings from GoVacuum.com,
What it sounds like is that your belt has either broken, or has been stretched to a point where the brushes won't spin. What you'll need to do is turn the vacuum cleaner upside down and turn on the vacuum. Are your brushes spinning at all? If your brushes are spinning, when you put the machine on the carpet, does the brush stop spinning, or slow down noticeably?
If either one of these happen, you'll need to replace the belt. Most Bissell uprights will use Bissell Style 7,9, and 10 belt (3 styles, 1 belt). The best way for you to find out what belt your machine takes, is to refer to your owners manual. You may also email me your model number, and I'd be happy to ship you the correct belt.
http://www.bissell.com/images/UserGuides/PT.pdf
The instructions on how to replace the belt are also diagrammed and explained at the above link.
There is also a troubleshooting page on page 14.
Please email me if you have any further questions, I'd be happy to answer any question you may come across.
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 18, 2008
  • 25 Answers
SOURCE: Smells like wet dog
I would do the following: Wash the HEPA filter (the circle shaped spongy one) with a very mild disinfectant mixed with luke warm water. Allow to dry VERY thoroughly before re-fitting.
Replace the filter (they are about $10 australian from the service centre last time I had one replaced)
You may also want to check for moisture in the dust hopper, also in the cyclone bit.
Hope that helps!
Posted on Jun 22, 2009
  • 563 Answers
SOURCE: I have a Lift Off Pet Bagless upright and ever
Check the rotating blades. If they are bent or out of synch, then you have to replace the blades, even the motor.
Posted on Oct 30, 2009
Coleman37
  • 337 Answers
SOURCE: When vacuuming hardwood floor, hair gathers on
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Posted on Mar 14, 2010
  • 324 Answers
SOURCE: My husband uses talcum powder liberally and we
You can build a homemade soot trap like what oil burner service reps use. Please refer to the drawing. You start with a widely availabe bucket with an airtight lid (Home Depot sells one in their trademark orange color for example). Along with the bucket, you will need about 30 inches of PVC pipe - ideally you will get the diameter that matches your vacuum cleaner hose attachment. "Schedule 40" PVC pipe will work fine. This refers to the less expensive thickness of pipe- any home improvement store rep can help you with this, and if you bring in your hose and explain what you need to do they will gladly help you out! Finally, you will need a tube of silicone RTV sealant. Cut two holes matching the size of your PVC pipe into the lid of your bucket, and cut the pipe into two sections- one that will sit three to four inches from the bottom of the bucket, and one that will sit one or two inches below the lid. Put them into position and use the RTV sealant to hold them in place and also provide an air-tight seal. On the lid, label the side that has the long pipe INLET and the side with the short pipe TO VACUUM. This is CRITICAL so make sure you do it! Labels, paint, marker, crayon- whatever. Label them NOW!
Finally, you need a section of flexible plastic hose to connect your trap to your vacuum. Six to eight feet should work fine. You will have to be creative to make sure the connection between your new trap and vacuum are air-tight, but IMHO this adds a little adventure to the project... you want something easy to attach and remove, and by no means do you want to do anything that prevents you from taking your new trap off and using your vacuum normally. Hardware stores are bursting with all sorts of adapters and stuff! The same goes for the inlet side of your trap, but hopefully you matched the pipe up to your pickup hose to where it makes a nice tight fit and works without adapters.
After the RTV cures (about 24 hours) and you are satisfied that everything is in order, you are ready to use your soot/dust/fur trap! Fill the bucket about 1/3rd of the way up with water. Make sure that the long end of pipe is under water by about 2 inches. It is VERY IMPORTANT that the end that goes underwater (The INLET) is hooked to your pick-up attachment.... You should have labeled it INLET already.
The whole idea is that whatever your vacuum sucks up gets pulled underwater first, trapping it before it gets near the vacuum cleaner. It has worked for decades for oil burner service techs to keep furnace soot out of their vacuums, which would be destroyed after one or two uses otherwise.This will easily trap dog hair and talcum powder. Be forewarned that inside the bucket it will get very messy and it is vital that you clean it after every use.
Good Luck!
Posted on Mar 20, 2011
Vacuum is clogged with dog hair. How can clog be removed?
HI, it's Jim from Crucial Vacuum!
If your Shark vacuum is clogged with dog hair there are a number of general maintenance cleaning tips you could perform to help keep your vacuum working at its peak performance.
First let's check out your brush roll. Is there dog hair wrapped around the roll itself? If so remove it by pulling out the dog hair, or use a razor if its tightly wrapped around. Manually rotate the brush roll to help unearth any hidden clogs behind the roll.
If there's dog hair throughout your unit be sure to empty the dust cup after every use. When the dust cup isn't emptied often this leads to clogs and a loss of suction.
Also, be sure to check your vacuums hose for any clogs, or clumps of dog hair. Stretch the hose out as far as you can. If you notice a clog in a hard to reach place use a broom handle to unclog it.
Your Shark vacuums filters may need to be replaced, or washed and may be a source for a lot of the dog hair in your vacuum. Wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 11, 2015 | Shark Vacuums
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
We have a dyson dc27 total clean, this is the worst vacuum we have ever owned we have dogs so we vacuum about every other day our dogs have fin short hair and its hard to pic it up we have to go over the...
My vacuum engineer friend loves Dysons ~ he says that they keep him in business!!
The only machine that I have found any use on animal hairs is the Miele Cat'n'Dog model.
The turbo brush is excellent.
Dogs shed most of the time so that means to keep onto of the hairs you need to vacuum most of the time (once a day!).
Miele Cat and Dog Complete C3 Canister Vacuum
Pricey but mine is brilliant.
Dyson's are cheaper and now you know why!
Good luck
Apr 30, 2017 | Dyson DC27 Bagless Upright Vacuum
There is dog hair stuck in the hose-how do I get
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
nb,.n
May 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
iRobot Roomba® 562 Pet Series
Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
How to clean clear plastic thing in front of Bissell ProHeat?
you may have to run it to soften the hair, then you should be able to go under it with a rag to clean it.
Apr 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Hoover stamvac has hair trapped in it
Hoover makes a neat tool for cleaning the hair and dirt out, its called a "nozzle cleanout tool". You can contact hoover and locate a store near you.
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Lift-Off Pet Hair vacuum doesn't lift off pet hair!
very light "stuff" like dog hair will get stuck to the filter since that is where the suction goes. it's primary purpose was to keep dust out of the motor. This is a problem with many "bagless" cleaners. A bagged cleaner keeps all dirt and hair away from filters by utilizing the bag as primary filter. If you have alot of dog hair then this may have been the incorrect choice of a vac. all you can do is brush off the filter each time you use the vac. it will still pick up o.k. even when there is hair on the filter unless you leave it on day after day.
Jun 14, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dog hair from vacuum is being laid back onto carpet
my plush carpet and dog hair do not go together! I realized with this particular model and in my environment, the bag fills in one vacuuming! I literally dug out all the dirt I could by taking it apart and then changing the bag. Voila!
Mar 31, 2008 | Hoover WindTunnel Widepath U5397 Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
24 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
