Question about Casio G3011 Duplex LCD Watch
Is there a reset button? i put a new battery in with difficulty and it wont work. this is the casio g3011
  • 6,771 Answers
No! there is no reset it is possible the battery is not correctly seated, check to make sure the positive and negative match what the watch indicates, because if the battery is reversed it will not work. If you still have issues take it to a watch dealer.
Posted on Jan 01, 2011
Handleiding
mcdevito75 here, I think you mean handleing, or takeing care of your Casio watch. First look on the back cover to see if it says shock proof or water proof, if it does you have a liitle lee way in handleing your watch, what I men is, you can wear your Casio even if you do heavy work and even in a moderate rain. However most Casio watches should not be worn if your out in a driveing rain or if you do extra heavy work, such as use a sledge hammer, or heavy tools, keep your casio dry, and once every other daye wipe it clean with a soft dry cloth, also do not rest your Casio on it"s crystal (Glass) when you take it off.
Jun 16, 2010 | Casio G3011 Duplex LCD Watch
Wristbelt for the CASIO G-Schock G3011
Follow this link: http://www.casio.com/support/buyparts/ If you are not happy with CASIO service, it doesn't mean I gave you false info, so rate me properly.
Feb 04, 2010 | Casio G3011 Duplex LCD Watch
I can't seem to remove the battery from my Casio G-shock G-3011 I've opened the external casing, but i can't get to the battery
hello,
here is step to step removal of battery
http://forums.watchuseek.com/showthread.php?t=19704
enjoy
Aug 17, 2009 | Casio G3011 Duplex LCD Watch
Casio prt-10 and i broke the display. where i can buy lcd?
You're probably going to have to replace the complete guts. Lots of these digital watches have the little buttons on the sides of the case. Those buttons press small springs which makes contact with the button on the "movement". Be careful that the little springs aren't lost when you remove the movement. It's not hard to do, you just need the right parts. A small phillips screwdrive and a sharp probe makes things easier.
In some cases, you will need to force the stainless steel back past the rubber wrist band. These watches are nearly indestructible, so you can apply some force. Just don't apply it to the guts of the watch.
Jun 14, 2009 | Casio G3011 Duplex LCD Watch
Poor cassio watch display
You don't say how old the watch is and whether it has always had a display problem. I have seen several watches with weak displays, but generally they are older watches and I suspect the problem involves a corroded contact somewhere in the "movement". You might want to visit the Casio website and download a copy of the manual for your watch. It may say something about the display. If you watchis fairly new it may still be under warranty and again, contact Casio to see what you need to do.
Jun 13, 2009 | Casio G3011 Duplex LCD Watch
I just repaced my casio watch batteries but i'm
This may sound dumb but make sure the battery is in the correct side up. There should be a + or - symbol on top of the metal piece that snaps over the battery. If that's correct get a pair of tweezers and spread them open, and touch one side to the top of the battery and the other side down inside a little hole with ac marked beside it. That will reset the watch, and your display should come on.
Feb 28, 2009 | Casio G3011 Duplex LCD Watch
Need new watch band
Where can I get a watchband for Casio Model G3011?
Oct 17, 2008 | Casio Watches
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Aug 14, 2008 | Casio F91W-1 Wrist Watch
Casio G-Shock G3011
go here [url]http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2454&submit.x=68&submit.y=13[/url]
Oct 31, 2007 | Casio G3011 Duplex LCD Watch
Casio G3011 Duplex LCD Watch Logo
70 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
