Question about Ovens
Cooker burner locks out several times a day and has to be reset. Cooker serviced recently and solenoid replaced.
  • 5 more comments
  • mike19534 Jan 05, 2011
    Sorry thought I had already recorded this! The cooker is a Stanley Super Star oil fired boiler/ cooker, installed in 1994.
    Cooker is a Stanley Super Star oil fired boiler/cooker installed in 1994.
    Another expert please since first reply was written badly and difficult to understand.
    Boiler will often fire up on its own but can then cut out several times a day. Always fires when lock-out is reset. Boiler did not fire this morning until the lock-out was reset.
    Your comments do not apply to my boiler/cooker! Mine is a Stanely Super Star (SO/03161/94) range-type oven/boiler with a gross output of 22kW. My problem is the "burner lockout" button which has nothing to do with door locking; it does not have a cleaning facility neither does it have a built-in locking lever! Hence, all of your suggestions are not relevant.
    I thought that I had already posted a reply to answer 2!
    I think that you have the wrong cooker! Mine is a Stanley Super Star range cooker/boiler (SO/03161/94 output 22kW). It does not have a "self clean" system, hence no door lock or associated lever. My problem with my Stanley range is "burner lock out" as stated many times!
    Your suggestions are completely irrelevant.
  • mike19534 Jan 10, 2011
    Oil-fired Stanley Superstar Boiler. Boiler lock-out.
    This is now the 3rd comment that I have receved from FiixYa. It is rubbish and equally as non -relevant to my boiler cooker as the previous two comments. You are wasting my time - I want nothing more to do with FixYa.
  • Tim Rogers Sep 16, 2013
    Hah! I have been servicing a Stanley super(not)star today and have come across a similar problem. The burner runs for a while then locks out. My guess is that the oil pump is on the way out. These range cookers are a pain in the ar*e as getting spares for them takes far too long and access to the burner is extremely awkward. Enjoyed your comments about Fixya - it seems that people have a desperate need to say anything (don't know how to underline on ipad) even if it's utter tosh...... I realise it 2 years later but I had a desperate need! Tim
  • Ovens Master
  • 43,501 Answers
When you are talking about a "cooker" do you mean oil burner??? On a heating boiler???
If so... get back to me with the type make and model of the burner and I may be able to help you ....even if I can't it will give more info for others and maybe someone else can help you...
Thanks!!
heatman101
Posted on Jan 04, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Jan 05, 2011
    The first thing that you need to establish is whether or not the cooker is actually firing every time...lockouts from not firing are different then firing and then not staying on...
    If it is firing and then cutting off hte flame sensor may be bad or the control is bad...
    If it is not firing all the time then there could be nozzle issues, transformer issues or even oil pump problems...
    These burners are NOT fun to troubleshoot as they have so many different things that can go wrong...and figuring out the one problem can be a bugger...
    See if you can narrow the problem down a bit and get back to me...
    heatman101
  • 414 Answers
Pressure probably was low, but went right down when the burner locked out and the primary store went cold. Check the expansion vessel for the correct air charge, remember to have a drain open whilst you pump up the vessel, the water pressure will have played no part in the burner locking out assuming it was not overheat lock out?
check that the PRV is not dripping and another hot spot on the heatslave is the AAV on top of the heatstore.
As you've already had the solenoid replaced the only real other culprit would be EBI Ignition transformers.
Finally, if you cannot follow above steps or they make no sense, please get a professional in as this is dangerous stuff :)
Posted on Jan 08, 2011
    Genius:
  • 1,416 Answers
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com if you can not fine the manual again.
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
However,Your ovens, like many others, have a built-in locking lever that is used when setting the oven to its self-cleaning setting. The ovens have an internal sensor that keeps the locking mechanism locked until the cleaning cycle is complete. An oven that never completed the self-cleaning cycle may appear to have its lock stuck leading to an erroneous idea that the mechanism itself is faulty.
Instructions and material needed to solve the problem
  • Access to oven power cable, Access to the circuit breaker switch leading to the oven's wall outlet, Oven instruction manual
  1. Consult your oven owner's manual or instruction manual about the self-cleaning function of your oven. At this point, you can choose to allow the oven to complete its self-cleaning cycle, which will permit release of the locking lever when finished, or you may proceed to the following steps.
  2. Turn off all dials of the oven and unplug the unit. Alternatively, turn off the circuit breaker switch connected to the outlet being used for the oven. Keep power removed from the oven for about five minutes.
  3. Before restoring power to the oven, try to unlock the oven by sliding the lever in the direction necessary to unlock, according to your oven owner's manual. If it unlocks, restore power to the oven. If it doesn't unlock, restore power to the oven and try once again to unlock the oven. If you are still unable to unlock the oven after following all of these steps, consult a certified technician as the locking mechanism contains no user repairable components.
Good luck and thanks for using fixya.
Posted on Jan 05, 2011
  • 1 more comment
  • Oloyede Monsuru Jan 05, 2011
    How can i help?.
    thanks.
  • Oloyede Monsuru Jan 06, 2011
    How can i help?.
    Thanks once again.
  • Maura Tobin
    Maura Tobin Aug 10, 2014
    my stanley oil cooker is cutting out after 20 minutes what can the problem several have looked it but still not fixed
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
GJP85200 Whirlpool Oven display went dead
First you need to check if a supply is available to the machine. The safest way to do this is with a non-contact voltage detector. You can get one for around £10. (Also called volt sniffers by some) If you have an electrical supply to the machine I would call for service, use yell.com to contact your most local cooker engineer. If there is no supply you need to check back at your fuseboard to find out why.Have you reset all the trips?. Is there a spur with a fuse in it between the cooker and the fuse box?
Apr 04, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Ovens Logo
1,016 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
