Question about Samsung HCM4215W 42" Rear Projection Television
Hi, I have a Samsung Tv(42") model HL-84266W that
  • Samsung Master
  • 8,457 Answers
Ur tv have CRT tubes coolant problems.Must be replaced CRTS coolant chemicals,to clear it up.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy these coolant kits,it also came with a tutoring DVD also.
Posted on Jan 01, 2011
Samsung model hl-s4266w.. I can see the TV programs but it has gotten really dark. i think it's the bulb, but when i look on the back, the bulb is still on. Could it still be the bulb that needs to be...
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Samsung HL-S4266W 42" HDTV
The tv has been shutting off shortly after it is turned on. It will stay on after a few cycles of turning it back on, or if you unplug it and then turn it back on. yesterday it was on and it shut off and...
Hi and if its not the power supply board!??
for me its look as an component have burn in the
highvoltage deflection circuit like the horizontal driver or the output transistor near the HV tranformers
or a regulator for b boost the best is maked a trouble shouting in the set by a good technician
he should find wath is the problem verry fast
that is an hour jobs max
hope that give an idea
Apr 07, 2010 | Samsung HCM4215W 42" Rear Projection...
Tv makes buzzing noise then picture fades and eventualy shuts off
Ur colors wheel is dead,must call tech.for this is very difficult to take out,and replaced have no tv tech. experience.Best to call tv shop service,to replaced this colors wheel,and have warrenty on it.
Jan 11, 2010 | Samsung HL-P5663W 56" Rear Projection HDTV
DLP TV lamp went out, new one doesn't work either,
Well you have a Samsung TV, in this case, it's most probable that you might have an issuw with your ballast. It might not have enough energu to keep up with your new lamp. You might ask yourself, How could this be if it worked with the old lamp? Well the old lamp didn't have all of it's gases, like it used, when you recently purchased the tv or lamp, and as time goes by, those gases tend to go out.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung 42 inch projection tv picture like watching coneheads seems to stretch
This is a symptom of a defective capacitor in the vertical circuit, but not usually with a DLP machine. Can you post the model number of your set please? I should be able to provide you with the part designation of the defective part once I get the model number.
Thanks,
Dan
Oct 27, 2008 | Samsung DLP HL-P5663W 56" TV
Color problem
Samsung color wheel fix
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung sp-r4232 cloudy image
How do you have television hooked up?
Jan 10, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HCM4215W 42" Rear Projection Television Logo
413 people viewed this question
Henry  Thomas
Henry Thomas
