There is an error in connect........... - Computers & Internet
    Scholar:
  • 69 Answers
If the error in connecting to the internet or to a LAN is prevalent with all network adapters, reset the TCP/IP Protocol stack byrunning the following command from the command prompt window:
1. Go to start menu and click on run.
2.Type in cmd.exe and press enter.
3.In the command prompt window,type in the command:
netsh int ip reset C:\connlogreset.log
The command will reset the TCP/IP protocol stack to it's defaults, and the reset data will be logged in the text document connlogreset.log.
If the above fails, disable any protocols that are not needed in the connection, e.g. SLIP(Serial Line Internet Protocol for Linux) as it's only used to connect to Linux servers in a LAN.
If using a broadband modem, disable NDIS driver wrapper from the GSM broadband client software provided with the modem, and update the software if possible.
Posted on Jan 01, 2011
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Error Code :51100 Nintendo Wi-Fi Connection Setup
Error Code: 51100
The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router.
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
Jun 01, 2011 | Nintendo DS Lite
Trying to connect to internet error code 051112 - 1
Error Code: 051112 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Connecting from a wireless home network:
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a Hotspot
  • Ensure the Hotspot location does not require an internet browser to setup an account, accept a use agreement, or enter a password before accessing their Wi-Fi serice. If the location requires any of these items, you will not be able to connect to the Nintendo WFC.
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction. Signal strength can vary, depending on where the access point's signal is coming from. (Please do not sit or stand in places that will interfere with the location's customers or staff.)
  • Orientate the Nintendo DS so that your body or other objects (such as walls, plants, furniture, and other people) are not blocking the signal. Also, make sure there is no interference from wireless phones (cell phones are okay).
  • If the connection continues to fail, this Hotspot may have their router set up in a manner that is not compatible with the Nintendo WFC.
Aug 16, 2010 | Nintendo DSi Black Console
Define 54.18 ERROR code on a Hp Laserjet 5500
According to the HP Service manual, there is no 54.18 error.
The listed errors are:
54.1 Temperature error
Check the fuser. See 50.X fuser error.
54.3 Image density sensor error
Check the connections. Replace the color registration detection assembly.
54.5 Colour registration sensor error
54.6 Image density error
54.7(Y), 54.8(M), 54.9(C), or 54.10(K) Drum phase sensor error
Check the connections. Replace the drum phase sensor for the indicated color.
54.11(K), 54.12(C), 54.13(M), or 54.14(Y) Toner sensor error
Check the connections. Check the cartridge and replace it if necessary.
54.19 Transfer Belt error
Check the ETB connection. Replace the ETB. Replace the DC controller.
It is most likely that you have a faulty Toner Cartridge.
Jun 21, 2010 | HP Color LaserJet 5500 Printer
Can't connect error code 051100-1
Error Code: 051100The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
Apr 10, 2010 | Nintendo DSi Matte Blue Console
Error code 051101
Error Code: 051101 The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do: Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
Feb 03, 2010 | Nintendo DSi Black Console
Canot connect to internet error code 051100-1
Error Code: 051100 The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
Feb 02, 2010 | Nintendo DSi Black Console
ERROR CODE051110
Error Code: 051110 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Jan 24, 2010 | Nintendo DSi Black Console
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Trying to connect to wifi usb connector and keep getting error code 52203
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from: What to do:
  • Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
  • America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
  • If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
Connecting from a non-partnered Hotspot:
  • The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
  • If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
  • Try another Hotspot. To search for known Hotspots in your area, click here.
Jul 16, 2008 | Nintendo Video Game Consoles & Games
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
