Question about HTC HD2 Smartphone
My phone was unused for a day and the battery went totally flat. I charge the battery but there is no yellow light on the phone. The yellow light always appear when I charge the phone.
    Problem Solver:
  • 10 Answers
Pull the battery out and reinstall to reset, charge again, could take a few mins to get charge light maybe need to replace battery with new one ??
Posted on Jan 01, 2011
Testimonial: "helpful suggestion, Thanks."
MY scooter battery needs recharged and I plugged it in and it indicatied it was fully charged and it wasnt. So I bought a new charger and that is showing the same thing. I dont know what to do next. The...
Has the scooter been stored unused for a while? If so, the batteries may have gone solid from improper maintenance. There is a gel inside the batteries that needs to have current run through it at least once a week to keep them fluid. The charger is showing a green light because it senses the batteries are full, but instead of being full of power, they are full of crud and need to be replaced again. If the batteries have been properly charged but you still cannot get power, check all your connections to make sure they are tight and that your fuses are not blown.
Oct 12, 2010 | Electric Mobility Health & Beauty
My battery on my iphone runs out in 2 to 3 hours. What to do?
I think you must check your charger and if ok replace your battery
Mar 31, 2008 | Cell Phones
Tip
Mobile phone battery not holding charge and going flat to quick
hi, now this is a very common problem the only thing you can try is to let the battery go totally flat and keep switching it on untill the phone wont even light up.
Then what you need to do is give it a full charge for at least 8 hours this may lengthen the time your battery takes to go flat.
Now what the shop should have told you and didnt and what they should tell you in the owner's manual and dont is that once a month you are supposed to let the battery go totally flat and then do full recharge.
Doing this will ensure you get maximum time out of the battery and it makes the battery last at lot longer before you need to replace the battery.
If after doing this your battery only last an hour or two then the chances are the battery needs replacing so if you do this just remember to let it go flat at least once a month as the battery never does a full charge due to the fact that the battery never goes totally flat so this then causes bad cells in the battery so follow those rules and your battery will last longer than normal
on Dec 03, 2009 | Cell Phones
My storm battery icon was yellow then went to all red. I have it turned off and charging right now and indicator light is blinking greenish red? Is there a problem or does it just need charged
Battery icon goes yellow when charge is low, red when about to go off, yes, that's OK. Recommend give it more time after all the bars are full-white, to trickle more into the battery. Lithium batteries don't seem to like being flattenend and left flat in my experience.
The light blinks for all sorts of things, might also have pending messages, etc. Can use the Storm OK while it's charging, just hold down red button to turn it on again.
After turning on, sometimes the cellular receiver does not turn on until battery is more charged. Wait 10 mins and then try to make a phone call, you may get a message saying it's off, do you want to turn the receiver on - just say yes.
That should keep you going. Nice phone.
Sep 09, 2009 | RIM BlackBerry Storm 9530 Smartphone
Can not turn on! my garmin nuvi 200w I think it is locked,
if ther battery went totally flat place it on charge for an hour or so to revive it. Max battery life in storage is 4 days with a good battery.
Charging it even tho the charge light may not show should build up enough charge to eventually show the light and allow you to turn it on. It should remain on charge for 5hrs.
Other possibility is a collapsed cell in battery, replace the battery
Jul 24, 2009 | Garmin nuvi 250 GPS Receiver
After leaving my Sony DSC-T2 camera unused for only a couple of days the battery was flat. I recharged it fully but again it only lasted a day or two. I assumed the battery was dead and I purchased a new...
If the troubleshooting section in the back of the user guide doesn't help, I sugget getting in touch with Sony and asking them if it's normal, the only thing I can suggest in the meantime, is taking the battery out while it's not in use, or recharge it a few hours before you're due to use it. Phones get like it after a few years and with technology advancing the way it is these days, you'd expect a battery life lasting longer than a week, not a day.
Things to consider:
1. When it's off, is it off or left on standby?
2. Where did you buy both the camera and batteries from?
3. When you charge it up, do you charge it up with a half charged battery or a totally dead battery?
Jul 20, 2009 | Sony Cyber-shot DSC-T2 Digital Camera
My tracfone will not come on,only the lights
You'll wanna ensure your phone is totally charged. Also, let it completely drain before putting back on the charger. This will help with the charging memory.
As for the phone. Do a master reset: to do a "Master Reset". I went to "Settings," "Other Settings," "Initial Setup," "Master Reset" and put in the security code. "1234" is the security code if you have not reset yours.
It'll get the phone back to as you got out of the box, day one! Your numbers will be fine. You'll notice the ringtone and the wall paper will be the orignals.
I know this will work!
Cheers!
Feb 04, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Motorola Q9
It's sound to me like you guys might have dead cell... change the battery and it should be fine.
Battery Maintainance
1: Try and charge battery when it's totally off/flat
2: Only charge battery till battery full indication comes up.
3: When disconnecting battery switch phone off first.
4: When phone is not in use don't leave it in the sun facing the battery.
.....Hope this helps.
Don Cass
May 12, 2008 | Motorola Mobility Q9m Smartphone
Battery not charging
Hi this problem is going to ba faulty battery i had the same problem after replacing the battery it was fine.
The problem was a couple of bad cells inside the battery but what your supposed to do to prolong the life of the battery is to let it go totally flat once a month i mean totally flat so it wont even light phone up then do full charge this keeps the cells good in the battery so remember to do this often should keep the battery lasting ages let me know if you need further assistance
Jan 22, 2008 | Nokia 3110 Cellular Phone
Battery life under 5 hours
have you let the battery go totally flat as this is recomended to do every couple of months because if you dont let the battery go totally flat this stops the battery from full recharging and will cause bad cells in the batt so i would let hte battery totally flat till it wont even light phone up then fully charge for 16 hours see if this improves the battery if not then the charger is probably over heating and cutting off so you could replace the charge hope this is some help to you
Nov 19, 2007 | Samsung SGH-D900 Cellular Phone
HTC HD2 Smartphone Logo
161 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
