Question about GE Spacemaker JVM1640SJ Microwave Oven
Smell of burnt rubber or plastice came when usinging ge spacemaker jvm1440wd003.
    Brigadier General:
  • 8,909 Answers
Was the smell inside the cavity or inside the case?
If inside the cavity it could be the waveguide cover. If inside the cabinet it could be a bad contact somewhere.
I wouldn't use it again until you find out what is causing it.
Posted on Jan 01, 2011
Have a 10yr old ge microwave--was heating up food when it started making a loud bzz noise and then burnt plastic smell came from outside of the microwave and it didn't heat up food. It was working fine...
Yes it is definitely the magnetron and yes you could change it your self if you are good with electronics and tools (considering that the MAGNETRON DRIVER CIRCUIT is OK) but it is normally cheaper to buy a new microwave oven
Sorry!
Jan 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | GE JVM1440 Microwave Oven
What is the best way to remove burnt smell from microwave. My dgthr burnt macaroni
Put vinegar in a glass and microwave it.
After it boils take it out and clean your microwave with a disposable towel. Hope this helps.
Mar 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is ge spacemaker model # jvm1650sho5. when microwave is turned on about 4 seconds later it starts making a noise and has a burnt smell. The smell comes from the vent on upper left side and the...
this sounds like the magentron may be going. have you had any issues with it not heating? check your warranty book, some mags have a 3-5 year warranty, otherwise it's probably not worth repairing.
Nov 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Capacitor burned out? horrible burnt smell.
YOUR GOING TO NEED A NEW MICROWAVE . the cap may be bad but the real bad smell you have is most likely the HV tranformer , if the magntron shorts to ground there will be a small smell if you dont pick up on that and your microwave is set to run another few mins the transformer will overheat and burn , then the fuse blows and the controls shut down . the end result , you have more parts bad than you have good . if you google " GE SPACEMAKER MICROWAVE FIRE ' you will see your not the only one , its getting to be COMMON . good luck
Mar 08, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl1800 microwave "burnt paper" smell
Hey
There are several things you can do to help git rid of that smell
First get a mild cleaner with bleach (soft scrub ect!) and clean entire oven inside and try getting that scorch mark off! a little pressure should lessen it ! (there is no filter inside! The plastic inside covering holds smells for a long time! you can also put a cup of white vinigar inside warm on high for 1 minute and leave in overnight!
Please take a second and rate my response
Thank You1
Jan 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker II - Burning smell and no heating
You may have a failure of the H.V. rectifier. I would recommend that a trained technician replace this part due to the high voltage potential.
Jun 02, 2008 | Microwave Ovens
GE Spacemaker XL 1400
IF THE UNIT IS STILL UNDER THE 90 DAYS BRING IT BACK TO
WHERE YOU GOT IT BEFORE IT STARTS A FIRE!!
Jan 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
129 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
