Question about Hotpoint Dryers
How to fit a new belt to hotpoint tl71 - Hotpoint Dryers
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/0079.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 08, 2008
Does Hotpoint Ultima Auto Dryer TL71 require outside vent? if so is there an access at rear of machine?
page 6 it is on the right rear of dryer:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Dryers/HBTL71.pdf
Dec 25, 2010 | Hotpoint TDL14 Electric Dryer
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Jul 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Belt on a hotpoint wf250
open it up, see wat thensions the belt, loosen that up and fit new belt. retension
Apr 19, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Dec 04, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Dryers Logo
310 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
