Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Does a 2020 JD gas have a differential lock - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
    Problem Solver:
  • 6 Answers
Some had this option. If yours does it will have a pedal on the left side foot plate toward the rear end. If the pedal has been removed the shaft should still be there sticking out of the transmission housing behind the PTO engage lever.You have to hold the foot pedal down to keep it engaged. Sometimes when you release it will stay there until you take pressure off the locking mechanism by turning the steering wheel one way or the other while the tractor is moving.
Posted on Jan 01, 2011
Compression in a 1966 john deere tractor its a 2020
is this a multi cylinder diesel farm tractor or what
remember that questions go global and you have to be specific in details as a jd unit 202 in your country may be a 1212 or what ever in another country
however moving on , if it has more than 2 cylinders , the problem can be a head gasket blown between adjacent cylinders , cracked head or valve problem ( burnt or incorrect valve adjustment)
same ideas apply to petrol engines as well
Dec 15, 2015 | John Deere Garden
Jd 2020 pto lever is stuck and will not engage
It could be corroded... water, dirt, etc, could have finally taken a toll on it.... Try spraying some electrical friendly lube on the shaft on the switch and try open and close it without the machine running... If not. You'll have to replace the switch.
Sep 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I cannot get the three point hitch on my tractor to come down. The internal and external controls will not work and even heat will not loosen it up
HAVE YOU TRIED ADJUSTING THE DOWN SPEED? ON MY
1967 JD 2020 THE ADJUSTING SCREW IS LOCATED AT THE
CENTER OF THE TRANSMISSION CASE BELOW THE FRONT EDGE OF THE SEAT. LOOSEN THE LOCK NUT AND
ADJUST THE SCREW TO OBTAIN THE DESIRED SPEED.
Jan 02, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I need a good part number for my jd 2020 starter 4 cyl gas
Is it direct drive or gear? We carry both...your talking 157.97 plus S&H for Direct and 235.90 plus 60.00 core fee and then S&H for gear drive...both delco starters. ediesinc@gmail.com for more info.
May 27, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a JD 2020 1970. The brakes lock up when I
sounds to me like the caliper/piston/cylinder is freezing up on it
try looking at replacement
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
On my jd 950 the rear end will not engage unless i push down on the differential lock
Is yours automatic transmission. The lever in the back either engages or disengages ... the lever may be bent ... check it.
Oct 09, 2009 | Garden
I have a 2020 jd it over heats after about 1 hr work radator is clear?
that radiator is not in the best place ,wash it out real good it usally has hydo leaks that drips on the radiator then collects dirt
Jun 29, 2009 | John Deere Tractor Side Screen...
Clutch problem
Hello:
It Sounds like the Clutch Idler is Bent and Requires Replacing.
A Homeowner can Replace the Clutch Idler Arm and Pulley with Little to No Worries.
You can View a Breakdown of this Unit at the Following Site Addy.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Enter the Model Numbers 2020 and CLick Search. Now Select your Model and then Select Sectional Index.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
239 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
