Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
I want to know the ft3 of my Kenmore model 596.68147891 Refrigerator.
  • 62 Answers
SOURCE: i need to find replacement
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Posted on Dec 07, 2008
  • 306 Answers
SOURCE: Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Feb 04, 2009
woodchuck789
  • 4070 Answers
SOURCE: model 596 50392001 side by side panel between
This is uaually caused by the condenser fan not running. It's underneath the fridge behind the cardboard backing. Should be running when compressor motor is.
Could be caused by ice buildup on coils behind the back cover inside the freezer. This would be an auto defrost problem.
Posted on Jul 10, 2009
localwonder
  • 6784 Answers
SOURCE: The refrigerator side is not cold.
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Aug 27, 2009
Testimonial: "The information was helpful and solved my problem. I also learned something about the operation of my refrigerator. Thank you"
  • 20 Answers
SOURCE: Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
Posted on Apr 23, 2010
Need too know where is the timer located on my Kenmore refrigerator model number 596.66952401
I don't believe it has one, it operates off the controll board. Sorry to ask but what is the main problem with this unit?
Mar 08, 2016 | Kenmore Refrigerators
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I AM LOOKING TO BUY A NEW REFRIGERATOR AND NEED TO KNOW THE CUBIC FEET OF KENMORE MODEL 106 59592990
25 cubic feet
Here is a link to the owner's manual:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10659592990/0582/0165000?modelNumber=10659592990&diagramPageId=&documentId=
Dec 01, 2014 | Kenmore Refrigerators
Need to know the exact height of the sears kenmore elite refrigerator model 52704100
You should be able to find it in the manual
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-59675532400/0583/0161000?modelNumber=59675532400&diagramPageId=&documentId=
Oct 10, 2014 | Kenmore Refrigerators
How much air space sould a l7 15 have
For a sealed encl. 1.5 ft3 for a vented (ported box) 3 ft3 - 6 ft3
May 15, 2011 | Kicker Car Audio & Video
I need to know which is the Serial or part number of the Water filter of the Kenmore Refrigerator Mod 106.58953800 I need to replace it and get a great price Where?
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/9030/0046/046/Model-10658953800/0582/0165000?keySuffixId=&productTypeId=&searchModelNumber=10658953800&blt=06&subCompDesc=CABINET%20PARTS
Sep 05, 2010 | Kenmore Refrigerator Replacement Water...
Kenmore model 795.7500401 need to know cu sq ft
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Aug 27, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
An iron anchor weight 600lb in air. how much force is needed to lift the ancher when it is submerged in sea water? the weight density of iron and sea water are respectively 480 lb/ft3 and 64lb/ft3.
Hi .. The anchor will be bouyed by the amount of sea water that it displaces .. 600#/480#/ft3 = 1.25ft3
1.24ft3 of sea water = 64#/ft3 X 1.25ft3 = 80 # lighter
so the force to lift the anchor from that depth will be 520# ...
but as soon as you move it .. the force will change due to the varying density of the sea water due to the presure of the depth of the water ltself .. same as the density of air varies with altitude ..
so this is a finite answer
Thoughts?
Jun 27, 2010 | Flotec TC2104 0-100PSI Pressure Gauge
Cubic feet size of Kenmore refrigerator
Yes, I found something on amazon, here: Amazon com Kenmore refrigerator manual I hope this was helpful. Cheers
Aug 03, 2008 | Refrigerators
Kenmore refrigerator 26' side-by-side Model 596.52673200
on the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Jun 10, 2008 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
109 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
