Question about Fujitsu Plasmavision 42" TV
My old plasma monitor tv only has s-video how do i connect my hd box and i dont even have scart on my tv.ive tried scart-s-video but no joy.
    Brigadier General:
  • 8,909 Answers
I have seen, on ebay, video convertors. That may be your only way out.
Posted on Jan 01, 2011
Is there a step by step process to connecting my panasonic plasma hd tv to my dishnetwork cablebox?
hi does your cable box have hdmi ports if so connect hdmi lead from cable box to to tv hdmi 1, if your tv doesn't have hdmi then connect scart lead from cable box to scart 1 on the tv hope it helps
regards
shaun
Jan 31, 2014 | Televison & Video
Connecting VCR ,cable box, TV
First connect the cable box to TV using HD-cable (if connection available) or component cable (three leads) observing the colors. Connect cable box to VCR with an S-video cable or SCART if you have an S-video out scart. Connect VCR to TV with another S-video cable (round connectors) or with a scart to an S-video in scart connection. If you are in the US, the scart connections don't apply.
Sep 30, 2013 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a Panasonic TX-P42VT20 and a SCART switching box from a number of devices (2nd Satellite receiver, DVD players etc.). This works fine with my old TV, but I only get sound and no video when I connect...
I expect the new Plasma is configured to RGB or S video. Check your menu settings and adjust to whatever the old TV was set at. Composite Video I suspect!
Feb 04, 2011 | Panasonic Televison & Video
I was using my ps 3 on my plasma tv connected by a HD lead. I then hooked it up to another tv using a scart lead and now it won't work. I hooked it back up to the plasma tv and it works fine. I need it to...
Got to settings in the PS3 Crossbar and go to display settings. The first one should say video output settings, click on it. It should say your connection type is HDMI. Select component/D Terminal and hit change. The screen should go blank. During this time plug it in to your other t.v by the scart. It should say "Can you read this screen?" hit yes and there you go. To go back to HDMI do the same.
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
I want to connect a sky+ hd box to my jvc gm-v42e can you tell me what leads I require to get 1080 resolution. The sky box has a hdmi connection but the tv doesn't.
Hi, I've just been given one of these. I'm not a 'Techy' but I am having the same problems as you so I'll share what I've found out so far.
The JVC GM-V42E is actually a plasma monitor, not a TV, as it doesn't have a built in TV tuner.
The picture quality is very good, as at the time it was produced, it was a top of the range plasma monitor for professional use, and was discontinued in about 2006. However, it is not HD/HD Ready, so you won't be able to use an HDMI cable or view programmes in HD. There is also no scart, so you can't connect it to the Sky box this way either.
I spoke to JVC Professional's technical department and they suggested using a scart to 3 BNC connector. The scart plugs into the Sky box and the 3 BNC connection plugs into the monitor. The monitor itself has loads of connections, the ones you want are labelled 'Component RGB/B'. The three pins you are after in this section are labelled 'Video' and each are called 'Y/G', 'Pb/B' and 'Pr/R'. This will connect the visual aspect, and you will also need a twin phono lead (red & white) to plug into your Sky box and into the monitor to connect the audio / sound.
I went to Maplin's and they don't sell these so I am trying a scart splitter that connects to the screen with a 3 phono lead (the red, yellow and white connectors). At the moment I am trying plugging these into the section marked 'Video B'. The 3 phono lead then connects to the splitter, where scarts from the Sky Box and DVD can be connected. I don't know if this will work yet - but I'll keep you posted and update this thread once I have managed to get it up and working...
Hope that helps... :-)
I have yet to try either solution, but will get back to you once I have tried them and tell you which one works.
Jun 19, 2010 | Televison & Video
SEGA MEGADRIVE
dont know how many times ive said this but
GET AN OLDER TV
it saves all that time you use trying to hook it up to a new one..it doesnt even have to be that old just not a plasma or HD tv, its much MUCH easyer and saves lots of time, and mabie even money
Apr 13, 2010 | Sega Megadrive Black Console
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Fujitsu Plasmavision 42" TV Logo
83 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
