Question about MSI Wind U100-016US Laptop
Only my desktop picture is there when turned on nothing else
  • 304 Answers
Hi.
Based on the information you have provided, it seems that the issue might be due to the "Explorer.exe" System file.
This is the file which loads the Windows Explorer.
The Windows Explorer in-turn loads all the required Startup Applications.
As the Applications are loaded and the icons are not displayed, you may run the "Explorer.exe" file manually.
By doing this, all the Startup Applications should be loaded.
Steps to run the "Explorer.exe" manually:
1) Press the "Alt, Ctrl and Delete" keys simultaneously. 2) Then, check if you are able to view the "Task Manager". 3) Click on the "File" tab and select the "New Task" option. 4) In the Run command window, type "explorer.exe" and press Enter. 5) This command should execute the "Explorer.exe" System File. 6) By executing this System file, all the Desktop icons should be restored.
Hope this helps.
Please feel free to contact for further information and assistance.
Posted on Jan 01, 2011
PC turns on, fans running, but nothing getting thru to the monitor. Getting string of 2 long beeps, non-stop Note: was watching a video on YouTube when the picture just froze and nothing would stop it...
have you just installed new ram? this usually happens when the wrong dimms of ram have been installed. try taking all them out and leaving just one stick of ram and turn on again.
please let me know if this helps.
i will do my best to assist you
Jun 11, 2011 | HP Pavilion p6210f Desktop 26GHz 6GB...
Startup 3 beeps then monitor tries to turn on but nothing what is it/?
RAM sticks are having problem.Just open the CPU cover and clean the RAM slots and refix RAMs. You can put one by one if you have multiple RAMs. check with different RAM slots.If you still get this sound you need to get new RAMs
RAM will look like as in below picture
Aug 29, 2010 | Gateway GT5408 PC Desktop
Red light when i turn on and nothing comes up on screen
hi make sure all cables are connected properly if no look it sounds like you have a memory problem. if you open the side of your computer case you should see a memory stick that looks like this picture below if their is more than one of them remove one and try to turn it on if nothing happens swap them over and try again making sure all power is off whilst going inside you pc . sdram.jpg
Feb 23, 2010 | Acer Aspire SA20 PC Desktop
My hp computer wont display picture and makes a beep noise when i turn it on
It should make one beep. That means it passed the self-test.
If there is nothing on the monitor (is the monitor light green or yellow?)
then the monitor is bad.
I suggest you try another monitor to be sure. Borrow one from a friend.
Dec 10, 2009 | HP Pavilion 512n PC Desktop
Just let Windows install IE 8 and now the desktop picture is over
Change the resolution. Right click in the middle of the screen over nothing, and select properties then select the settings tab and move the slider left for larger resolution.
Apr 28, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
No icons..nothing!?!
Try resetting the desktop. Right click on the desktop, click properties, then open the desktop tab. Change the desktop picture and see if that works. If it doesn't try a system restore. You will be able to access the start menu by pressing the windows key. If these don't work you'll need to run a system repair with your recovery or operating system disc.
Jun 14, 2008 | Gateway MX6025 Notebook Computer...
MSI Wind U100-016US Laptop Logo
75 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
