Question about Evga e-GeForce® 7600 GTS, (256 MB) PCI Express Graphic Card
HI, i recently installed a new 7600 gts screen card (replaced my old fx5500 - everything worked fine), now my tv is displaying everything in black and white... I've been through all the forums i can get and still no luck, i've tried: - changing between pal and ntsc - bridging out the two pins on the s-video side - changing resolution - replacing the s-video card i think its a driver fault but which one do i need or am i doing something wrong? (i've got driver 260.XX)
  • 385 Answers
SOURCE: no display for evga 6800 128 mb card after installing the driver in XP
Maybe you need to disable the onboard video in the BIOS settings.
Posted on Mar 21, 2007
  • 167 Answers
SOURCE: No connection to monitor
i would try the card in another mainboard, if available and watch the refresh rates. hope this is useful. and try other cards.
Posted on Nov 06, 2008
  • 207 Answers
SOURCE: Video card displays more memory than advertised
You likely got a board that was mislabled and packaged improperly, which mean that you just got a bargain. If it exhibits any severe faults then I'd call support and get it repair. But if its running properly I'd just appreciate your good fortune.
Posted on Nov 20, 2008
SOURCE: Black screen no signal
replace the graphics card, ours was going black here and there the last few months then finally it didn't work at all, we just replaced it today and the new graphics card (ati) works fine.
Posted on Dec 24, 2008
  • 192 Answers
SOURCE: Black and white colour on tv
Hi there. Try running the multiple display wizard in the Nvidia control panel.
Hope that helps
Posted on Apr 17, 2009
Make sure the card driver is properly installed just remove the card and check on onboard display slot you getting proper display.
Hope this helps. Please rate my response.
Have a good day
Dec 28, 2010 | Palit Microsystems GeForce FX5500, (256...
I have a hp iq780 touchsmart pc.recently nvidia 7600 graphic card got crashed & its display got corrupted so, i switched to the motherboard graphic card nvidia 6100.wanted help in recovering 7600...
if the hw is working fine then you can go to the device manager and uninstall the driver ... and then go to the nvidia website and install the driver sw for it
Mar 17, 2010 | HP TouchSmart IQ770 PC Desktop
Pc games hdmi black screen
check you direct x  by typing  dxdaig in run run the test and se if it passes if not the card driver is not binding to the direct x 3 d games will not play maybe sound .
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 28, 2010 | ASUS RADEON EAH4350 Silent 512M LP Video...
Ragnarok online freezes after installing geforce
probably that your power supply is not sufficient to handle geforce fx5500. you may try to install the latest driver for this video card or if not, try to check if upgrading your power supply will help
Dec 07, 2009 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
Media player won't show movie on tv connected to fx5500
you might try a lower resolution . or  roll back the driver to a older version  GeForce FX5500  93.71
Oct 19, 2009 | Palit Microsystems GeForce FX5500, (256...
Hope that helps
Apr 17, 2009 | Evga e-GeForce® 7600 GTS, (256 MB) PCI...
Problem installation video card
Hello Virna, i have that exact graphics card and dell GX270 desktop here at home, tho it has been awhile since i removed the Nvidia PCI card for a more favorable AGP card. From what i remember, first check your BIOS (hit F2 on startup) and select integrated devices, scroll down and make sure your default video output is either PCI (if available) or AUTO) exit saving changes. If that yields no result. Plug in a second monitor to your old integrated video output, if you can view windows after bootup from there, then you can install the proper Nvidia display driver for windows Xp (available here: ). After installing, right click on the desktop, select properties, display settings tab, and make sure the Geforce card is the main monitor and the desktop monitor. Click apply, unplug the integrated VGA output, and restart. Hope this helps.
Apr 03, 2009 | Evga nVIDIA GeForce FX5500 Video Card,...
Inno3D FX5500 256ddr tv-dvi 128b
how to download the driver of geforce fx5500 DDR 256MB(128bit)DVI+TV
Jun 09, 2008 | EliteGroup P4VMM2 Motherboard
Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Apr 06, 2008 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
Geforce fx5500
From your post, it seems like Windows is booting correctly, but your card isn't correctly displaying the signal once the machine tries to load into your user profile.
Go into Safe Mode and uninstall the drivers for the card. Go back to the beginning of the installation process and follow it step-by-step. If this does not help, try inserting the card first, and then installing the drivers afterwards.
Mar 27, 2008 | Palit Microsystems GeForce FX5500, (256...
Evga e-GeForce® 7600 GTS, (256 MB) PCI Express Graphic Card Logo
32 people viewed this question
Top Evga Computers & Internet Experts
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
