On the Mitsubishi WS65869, SD Tech said, "If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it." How do you remove the front screen and find this tiny switch? Will it require soldering?
    Brigadier General:
  • 8,909 Answers
If you have disconnected the keypad and it is now working, there will be a keyswitch stuck down.
Yes it will require soldering to replace it or remove it.
Hope that clarifies your situation.
Posted on Jan 01, 2011
Mitsubishi projection tv timer light is flashing
If the model begins with VS or WS or WT:
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and issecured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of theset---remove the inspection plate and follow the wires to the right--you canunplug both plugs(most have two and they are marked with letters and differents so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---
These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.
If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Apr 11, 2012 | Mitsubishi WD Televison & Video
Mitsubishi WS-65869 BLINKING GREEN LIGHT reset buttton will not correct problem, cannot turn tv on
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
SD TECH
May 02, 2010 | Mitsubishi WS-65869 65" Rear Projection...
The timer light keeps flashing but the tv wont come on
Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
You can call them and get a quote for repairing the receiver. There are also sites on the internet selling a kit for this repair.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Nov 10, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Constantly blinking green light
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD TECH
Oct 11, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Had a power outage and tv (WS55859 Mitsubishi) will not turn on...timer light flashes...Please advise.
SD TECH
Oct 10, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Timer light keeps flashing on t.v.?
SD TECH
Oct 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Green light keeps on flashing. Cannot turn on TV
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it should pulls out and is secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
SD TECH
Oct 07, 2009 | Mitsubishi WS-48613 48" Rear Projection...
Blinking green light
Did he try to disconnect the front keyboard on this set?
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
Did he try to disconnect the front keyboard of this set? it has the reset switch on it---------and the switch can cause this problem!
SD TECH
Oct 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
The power light keeps flashing tv wont come on...
SD Tech
Oct 01, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Green timer light on front panel continuously flashes quickly and the tv will not turn on. have tried the system reset and unplugging the set. Green light continues to flash
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
SD Tech
Sep 26, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
