I am currently using a Scientific Atlanta Explorer 4250 HDC (Comcast), a Sony KDL-40HX800 TV, and a Magnavox H2160MW9 DVR. When I record on the DVR with only the Cable box and the DVR energized, sound is recorded but the video has a message indicating that the HDMI/DVI output is blocked. If I also energize the TV or disconnect the HDMI cable from the TV, the video records as it should. Is there a solution?
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Posted on Jul 15, 2008
  • 17 Answers
SOURCE: We have a new cable box, Scientific Atlanta
sounds like the tv needs to be programmed to variable output on the audio control section in the main menu.
Posted on May 17, 2009
  • 7 Answers
SOURCE: How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
Posted on Jun 06, 2009
SOURCE: download movies from explorer 8300 hdc dvr to computer to burn
Not gonna happen. SA uses a proprietary file system. The USB is only designed for a keyboard or mouse when in a special diagnostics mode. The best you can do is use an eSata drive to the port on the back. IF you have the Mystro software on the box (most do) it won't even allow you to move programs to the storage drive until the box's drive is mostly full. Even then, I'm not sure that it gives you the option to choose what you want to offload.
You are best off buying a DVD burner (stand alone unit) or output the video to your PC. and re-encoding it to the file you want. Alternately, wait for the Series 4 TiVo with tru2way.
Sorry to be the bearer of bad news.
Posted on Jun 28, 2009
  • 11800 Answers
SOURCE: I want to hook up
Yes, you can connect your Panasonic to record from the Explorer box. But there are some limitations. First of all not all programs will be recordable - some of them have signals in them that forbid recording. Then all the recording will be done in standard definition, not HD. Finally the image quality will be lower than what you would expect from a dvd, more like a VHS tape.
To record all you have to do is to connect the units using the S-Video cable then select the S-video as source in the Panasonic.
If you get an error message then there is something wrong with the cable - replace it and make sure it's properly plugged in.
Posted on Jul 13, 2011
Code for scientific atlanta explorer 4642 HDC
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 27, 2015 | Philips "Prestigo SRU6006 Universal Remote...
How do I connect a Sony DVD DVP-SR210P to a Scientific Atlanta Explorer 4240 HDC and a Sylvania TV C320SLX?
I am not sure you can connect your DVD player to your cable box. You should be able to connect both your cable box and DVD player to your TV set with two HDMI cables. This link is a pdf_usecares file of the TV manual that shows how to hook up your dad and cable box.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0902617.pdf
Hope this helps.
Bob
Jan 04, 2015 | Sony DVP-SR210P Progressive Scan DVD...
How do i record a program and then watch another one, with the Magnavox H2160MW9
The unit is not a DVR capable of recording one channel and watching another. You can only watch or record one program at a time. Sorry.
Sep 22, 2010 | Magnavox H2160MW9 HDD Recorder
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
Download movies from explorer 8300 hdc dvr to computer to burn
Mar 11, 2009 | Pioneer DVR-107D DVD±RW Burner
Recording from DVR.
There is a firmware update posted on the Sony support web site. It takes care of the copy protect error. However, i have encountered an error where the recorder doesn't identify the input signal. It posts the message "waiting for input signal." I have no solution for this one yet.
Dec 17, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Dec 14, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
