Question about GE JE1640WA/GA Microwave Oven
Is the GE JE1640WA microwave still available? If not what is the compatable size microwave?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
your present unit is 1.4 cu ft capacity.
so just google, 1.4 cu ft microwaves
Exterior Depth 17.25 in.
Exterior Height 12.63 in.
Exterior Width 21.88 in.this is the size of your unit
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Is this model still available for purchase, if not what is the mdl # that replaced it?
Brenda, according to the GE website, that model is no longer available. They do have other models of similar size though. I have included a link to their website for that size microwave. Products from GE Appliances
Nov 17, 2014 | Microwave Ovens
Vent fan
I would be sure the filters and ducts are not blocked.
If you recently had a problem with your cooktop lights, that can affect the fan, too, but that can usually be economically repaired.
Jan 08, 2013 | GE JE1640WA/GA Microwave Oven
Jmc8100ad microwave oven no fan, no heat, no turntable
This is most likely a bad door switch or mount (usually the bottom but occasionally the top) or a defective relay or connection on the circuit board, which can be repaired.
Dec 15, 2011 | GE JE1640WA/GA Microwave Oven
What is the dimension for ge microwave model #JE 1640WA 001
For model JE1640WA001 , the spec sheet is located here.
In case you still don't have it, the owner's manual is here.
Jul 08, 2011 | GE JE1640WA/GA Microwave Oven
Our microwave looks and sounds to be operating normally, except that nothing becomes heated despite using different pre-set or manual modes.
If it sounds normal and not heating, you may need to replace the magnetron. this is a very common problem and normally occurs from the overheating of food.
if the microwave is making a gumming noise, then the diode needs to be replace.
Feb 08, 2011 | GE JE1640WA/GA Microwave Oven
MICROWAVE IS DEAD. IT CAME ON FOR 3 SECONDS AND THEN WENT DEAD. NO LIGHTS NO CLOCK NO NOTHING. IT IS BUILT IN OVER THE OVEN. IT WAS MANUFACTURED IN 1998.
sounds like you may have a blown fuse. . remove the 2 screws at the hop thats holding the ventillation grill. remove screw holding control panel. push control panel up slightly and lift out. . there should be another metal sheet covering the opening. remove and your fuse should be right behind that.
Feb 04, 2011 | GE JE1640WA/GA Microwave Oven
When door is open unit turns on and turntable spins. How to stop?
I have the same problem, and have not been able to find a solution. Any one with a coluiton?
Dec 01, 2010 | GE JE1640WA/GA Microwave Oven
Door latch broke.
Part is available,
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JE1640WA01&productCategoryId=0123245&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=E2134524&pop=flush
Eric
Nov 21, 2009 | GE JE1640WA/GA Microwave Oven
GE Microwave Model JE1640WA runs when the door is open only
You probably have a loose or broken door switch mount or the door may be slightly misaligned.
See:
http://www.microwavedisplay.com/safety.txt
and
http://www.microwavedisplay.com/disassembly.txt
and
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
GE JE1640WA/GA Microwave Oven Logo
1,300 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
