Looking for form: 50-9694 In reference to Honeywell Model HZ322 TrueZone
3 Suggested Answers
  • 415 Answers
SOURCE: please tell me how to reset my honeywell hz322
There is a way to restore the Factory Defaults via the Advanced Configuration Mode. Be careful, this will require thorough knowledge of you system to reconfigure based on your particular system. Here is a link to the manual to assist you with the Advanced Configuration Mode.
Specifically, pages 6 & 7. Visit this link:
http://www.forwardthinking.honeywell.com/related_links/zoning/truezone/install/69_2071efs.pdf
Posted on Feb 14, 2010
SOURCE: The emergency heat will not
I recently replaced my Honeywell EMMU-3U Mini Zone(2H/2C) panel with the Honeywell TrueZONE HZ322 Panel in my home. I currently have a 2 ZONE system, with a Th5110D1006 Focus Pro 5000 Thermostat up and down stairs. My questions are is that after installing the HZ322 panel, I only have heat working up stair's in ZONE 2 and ZONE 1 does nothing at all? After doing the Standard Checkout Procedure for function on Thermostat ZONE 1 DAMPER on the HZ322 panel its saying W1 for zone 1?
Posted on Dec 12, 2011
My TrueZONE HZ322 Panel has the purge light on constantly and cycles purging zones 1/2 every 40 seconds. How can I get to Normal mode and stop it from purging?
Sounds like a bad board in the panel. First verify that both dampers will infact close and open to eliminate damper problem.
Apr 29, 2018 | Thermostats Heating & Cooling
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
My hvac is not cooling. It is DATs/Zone controlled with a honeywell hz322. When I bypass the hz322 by shorting R W on the furnace control board heat runs fine. The HZ322 is reporting DATs temp limit e
limit will open when exceeded heat at heat exchanger. possible cause restriction on air flow(blower speed too slow, dirty filter or weak limit switch itself). when unit cooling down limit will reset and start back like nothing was wrong
Nov 17, 2014 | Heating & Cooling
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
How do i reset a zone circuit breaker in an hz432 control panel
remove cover and look for a micro switch labeled purge press and hold for three seconds all zones will reset all dampers will open equipment fan will run for up to five minutes and a yellow lite will flash
May 31, 2014 | Honeywell Truezone HZ432 Zone Control...
The emergency heat will not turn on in my system. I also noticed the emergency heat light does not turn illuminate on the Honeywell HZ322 TrueZone Panel even if the emergency heat button is pressed. The...
Yes, I believe you are correct concerning the circuit panel.
Regarding your heat pump not keeping up ...depending on what part of the country you live in, heat pumps are not the best thing to heat with. As you probably already know, once it reaches 32 degrees outside, the heat pump stops working and the electric furnace or heat strips come on to supply warm air. Frankly, when that happens, it's like turning on your kitchen toaster and blowing air across it with an electric fan. Doesn't sound to efficient does it. Plus, your electric meter is spinning like crazy and the power company is falling in love with you.
In my area (Virginia) most new home construction is now using what's called a dual fuel system. It's a heat pump, but it has a gas furnace backup for when it reaches 35 degrees outdoors. It's very, very efficient and a very comfortable heat. The gas furnace can run on either Natural Gas or Propane Gas.
In most cases this can be added to an existing heat pump system. The only thing necessary is the Gas Furnace, since you already have a heat pump and all the duct work. Could probably be added for a whole lot less than you''d expect.
The other option is to add a vent-free gas fireplace or vent-free gas logs, if you have an existing solid fuel burning fireplace. They are great for zone heating and/or supplemental heating. Plus, if you have a power outage in the middle of the winter, they'll still work, as they don't require any electricity.
I didn't mean to run own, but I hope all this helps you solve your heating problem.
Please let me know.
Rich
Feb 09, 2011 | Amana PTH123B25AJ Heat Pump Air...
Please tell me how to reset my honeywell hz322 hvac zone panel.
Feb 14, 2010 | Honeywell Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
