Question about Whirlpool Calypso GVW9959K Top Load Washer
The washer begins any cycle - fills, agitates briefly then gives warning tone and flashes what looks like F51 - If I push the power button it drains and shuts down. Thanks, R. Ashbaugh
  • Whirlpool Master
  • 8,220 Answers
I recently worked on one of these and took some photos.
A service manual and them photos are HERE
Posted on Jan 01, 2011
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Wash cycle wont finish start button does an 8 flash cycle
    Hi, these machines get corrosion in the door safety switch. I would start there.
    A little cleaning of the contacts might get that machine going. How about a repair manual?
    I have a few:
    http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
    Take care
    Apr 11, 2010 | Microwave Ovens
    The washer starts to fill normally, then agitates very briefly, stops, and begins to fill again. When watching the water fill, the water level does not rise at all, and if you push the button in to stop...
    It sounds like your drain hose is two low. If your drain hose is inserted into a drain pipe try extending the drain pipe to the same hight as the washing machine.
    Dec 27, 2009 | Washing Machines
    Top loaing washer fills then mostly empties repeatedly
    Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
    A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
    If it fills and stops, then starts agitation. Repair the drain hose.
    Mar 23, 2009 | Kenmore Washing Machines
    Soon as i set cycle and swich on door light flashes open
    hi,
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Hotpoint washer fills begins to agitate then refills continously.
    Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
    Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
    He2 washer flashing code f51
    I agree with sissssss. For my Maytag's F51 error, there were socks lodged between the inner and outer tubs, causing too much friction on the motor. This led to the computer reading poor performance of the motor. Please consider trying this easy fix before calling out service personnel or replacing circuitry!!! I spent hours under the machine messing with the motor and circuitry until I looked up at the translucent tub and saw stray laundry stuck where it shouldn't be.
    * Open the lid. Turn the bottom agitator by hand. Give it a good push. It should continue rolling on for several turns. If not, there is laundry stuck between the tubs causing friction.
    1.) Pry open the metal case lid. Take two flat head screwdrivers and wedge them in the crack about 6 inches from the left corner, and use them as levers to pop the metal lid, then the right corner. Lift up the metal case lid and lean it against the wall.
    2.) Take off the plastic ring that bridges the gap between the inner and outer tubs. There are many little catches all around the perimeter of the outer tub that hold on this plastic ring. Find those catches and put outward and upward pressure on those to release the catches.
    3.) Look down in the gap between the inner and outer tubs for stray laundry. I used a retrieval tool (Lowes 403255) below to grab the socks. There were especially several socks in the back right corner near the pump inlet. Run the drain and spin cycle and look again. There were more strays hiding that I nabbed the second time!
    4.) Snap the inner cover on by lining up all those catches and seating them. Snap the big metal lid back on by aligning and giving a good downward thump. Run the machine and be the hero, and don't be too mean to your wife about tossing those socks down in the crevices. Half hour and $3 for the retrieval tool is far better than all that RPS mess.
    Dec 03, 2007 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Calypso GVW9959K Top Load Washer Logo
    50 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
