Question about Wells LLF-14 Deep Fryer
Please help my deep fryer when i turne it on and after its hot the red release light comes on and then i have to push the reset button to make the deep fryer work again
    Master:
  • 505 Answers
The the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
Posted on Jul 18, 2008
How do i reset fryer
Depending on the model, the limit reset is located on the back of the control panel. You might see a little red button or there could be a little hole that you can poke a toothpick in the push the reset button.
Feb 12, 2015 | Kitchen Appliances - Others
How can i fix my savourex pro line deep fryer?
If the reset button is not tripped, it is likely that a wiring connector has failed or the on-off button is defective.
Aug 18, 2014 | Kitchen Appliances - Others
Trouble light comes on, can barely read the instruction around it(faded over time)It says to push a red button but not sure where the button is. Help!!
When trouble light comes on, it indicates that the hi-limit is tripped (this happens when oil temperature exceeds 450 Fahrenheit). The red button is located at the upper back panel of the unit, give it a push to reset but if nothing happens after resetting the button, the hi-limit needs to be replaced. Also try to check if the thermostat is working, stuck thermostat's mechanical contact will cause the hi-limit to trip.
May 05, 2011 | Wells F14 Deep Fryer
I have a tefal family pro fryer, when i switch it on the green light comes on instead of the red and it will not heat up. why?
Look for a reset button on the unit, Push it, you will hear a "click' then the unit will work. If not, there is an electrical problem, the element, or temp control is bad.
Apr 11, 2010 | Tefal FR4008002 Pro Fry Deep Fryer
Fryer not working
I also have the 4320 and my problem was a reset button on the back, down in a hole.
My reset button is red. Also there is a safety swith on the rear where you slide the control
unit into the grooves, it has to be all the way down for it to work.
Jun 29, 2009 | Bravetti K4320H Deep Fryer
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
Wells deep fryer won't heat
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
Mar 22, 2009 | Wells F-686 Deep Fryer
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
Lie up deep fryer
Hello. Could be three things, from what you describe, it sounds like your pilot is dirty, and not heating the thermopile enougher, and pilot off to energize the pilot portion of the valve. You could also have a bad thermopile, and no matter how long you hold it, or if your pilot is good, will it energize the valve. The last thing is that your hi limit has failed, and is preventing your gas valve from getting any voltage at all on purpose, as it is a temperature actuated switch that will shut the fryer off it it gets too hot, it could have failed and is now keeping the pilot from coming on, some of these have a reset button you can push ( usually red ) that will reset it, but then why did it trip? either your thermostat is out of calibration, the bulb may be broken in the tank somewhere, or it may just be tripping too early, like 375, instead of 425 to 460 depending on spec.
Hope this helped, and thank you.
Dec 02, 2008 | Imperial IFS40 Deep Fryer
Wells LLF-14 Deep Fryer Logo
196 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raymond Koonce
Level 1 Expert
Dennis Boxerman
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
