Question about Siemens Washing Machines
My new Siemens washing machine WM14S44P stopped functioning in midst of a washing cycle indicationg failure 23. What could be the possible reason and its solution ? How also to open the door as the load is still inside the washing machine ?
Washer_tech
  • 164 Answers
SOURCE: Washing Machine Door will not open
these door locks usually work with solenoids (sp) if you unplug the machine
Posted on Jun 24, 2007
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: sumsung J845 front load washing machine cannot open the door
What you need is a Samsung service repair manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 03, 2010
Testimonial: "Thank you for the manual, it helps me take off the top cover, but I am still in the same problem. But thank you all the same"
Siemens avantgarde washing machin stopping at rinse stage
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Mar 23, 2014 | Siemens Washing Machines
Error code F67
If the machine is NEW , you are entitled to FREE WARRANTY support and it must be availed, failing any tampering can cancel the warranty specially if the part replacement cost is high,
This can be error on the program controller unit, possible memory failure or a RESET could be a solution. Remove power and try once again before you call Siemens support.
Dec 30, 2012 | Siemens Washing Machines
SIEMENS WM1000 model timer to be connected.Kindly provide
i have a Siemens washing machine there is washing problem in washing ,some noise r generate like as chunk and wash cycle is not run proper and all function is work properly (darpan jain 9827622024)
Jan 25, 2010 | Siemens Washing Machines
My siemens washing machine does not spin but the water in and out functions are normal
Hi, I have a Siemens WXL166AGB washing machine that has started jolting violently when on the spin cycle, as if something is out of balance, never getting fully up to speed. Subequently it cuts short the spin cycle and leaves the clothes wet. Any idea what it could be. Thank you, Phil Vanes
Nov 08, 2009 | Siemens WD61392GB Front Load Washer /...
Brand new siemens w/machine childlock stops me programming
I think you press and hold for 10 secs to unlock, consult manual to make sure...
Oct 02, 2009 | Siemens WFXD8400UC Front Load Washer
Stopped in the midst of wash cycle. will not
If this machine has no sign of life I would check the electric outlet just to see that machine has juice going to it.
Next step would be to check the LDC board and make sure all diods are in one piece and are not damaged by water or any other element.
Aug 18, 2009 | Maytag Washing Machines
My dishwasher is sticks in between washing cycles
These mechanical timer machines have to follow a series of logical steps to complete the program - ie, empty. fill to level 1. wash. heat to temp. etc etc
My guess is the machine is not heating, as you say it works for part of the program - or possibly it is not emptying correctly? check water heating element and drain pump.
Program 4 eco is a separate program from 3, using low temperature washing - the machine does stop between 3 and 4 normally and doesnt carry on through.
Jan 30, 2018 | Siemens 24 in. SE64A630GB Built-In...
Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Jul 18, 2009 | Siemens WM14S794GB Front Load Washer
My Siemens WM14S791ME Frontloading washing machine had a message displaying that the pump was blocked. I drained the water out of the front, and found a bobby pin and a coin. Now I try to turn the washing...
F:23 means that there is a leak into the basepan of the machine and it should be checked by a competent repair person as sson as possible, the boby pin may have jabbed a hole in somthing or more likly there is a bad seal some were on the drum.
Apr 13, 2009 | Siemens WM14S794GB Front Load Washer
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service
Jul 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
53 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
