Question about Kenmore HE2 Plus Front Load Washer
F35 flashing. What does this mean? - Kenmore HE2 Plus Front Load Washer
  • Kenmore Master
  • 8,220 Answers
F-35: Analog switch/water level failure
Location on machine (number 20)
w10156252
Posted on Jan 01, 2011
What does it mean when F35 flashes on panel
I rekon ya got an F35 problem. Best take it down down to the shop and let em take a look as if ya mess round with it you'll stuff up yer warranty..
Nov 15, 2017 | Washing Machines
I have a kenmore Elite...F35 keeps flashing..what does this mean. Please help
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(&^%#
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
What does F35 flashing mean? I own a Kenmmore elite front loading washer and besides it being broke down most of time it is pretty but doesn't work most of the time. This week it is flashing F35, I bought...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%&#@
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
What does f35 mean
Hello there
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 means ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
The washer stops and flashes f35 and some times
F35
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Good luck
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sears Kenmore HE3 Error Code F35
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
105 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
