Power supply problem in matsui tvr180, in STR section, can u please suggest me the circuit diagram to rectify my problem
    Brigadier General:
  • 8,909 Answers
The power supply, from memory, uses an STR type power supply chip and is controlled by use of an opto coupler.
In my experience the opto couplers hardly ever give trouble, nor the STR's if caught in time.
Change the capacitors around that part of the board within the hatched area especially look out for 22 or 47uF 35 Volt start up capacitor.
Hope that helps but the models changed from week to week depending on which factory the ubits came from.
Posted on Jan 01, 2011
LG tv str w6754 glows and short. power supply is not working?
Replace that STR. Before replacing, check all the related component/s at the SMPS section [HOT] side. any one damaged component will make the replaced STR to fail. If you wish to get some details; check the site linked here. Pull up older posts.
SMPS Circuit diagrams [STRW6754] of many popular brand TVs and other devices are given.
Search the site by type in the "BRAND NAME" or the STR number; of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | LG Televison & Video
Power supply board not working, what section i have to cheke...?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 03, 2016 | Televison & Video
My china crt tv uses str w 6554 but has a fault in power when you fuse it with a bulb it blick the bulb bright.
Check the entire circuit around the STR for any faulty component/s; especially to used Zener diodes. You should check each component in the power regulator section circuit, before replacing an other STR. Any of the faulty components at its circuit, might damage the new STR too. Be care.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Power supply regulator section circuits to some popular brand TVs are given. Search the site by the number of STR, used at your TV.
Jul 20, 2014 | Televison & Video
Str f6707a circuit diagram (power on power led glow but power led off after 1 second)
LG may be able to supply a circuit diagram that will enable you to determine the cause of power supply failure.
Apr 29, 2014 | LG Televison & Video
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
In onida ky thunder strf6654 getting burn,fuse blown when also change of str.????
Check all the associated components at the power supply regulator section circuit; especially check the zener diode/s. Replace them. Replace the STR only after replacing these components. There is a chance to these components too can damage, when the original STR has burned out by any reason. If you wish to get more, about the schematic diagram; check the site linked here. Type in the number of STR in its search box, or Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. http://electronicshelponline.blogspot.com/
Aug 06, 2013 | Televison & Video
Lg tv str w6554a power supply problem find
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" or the "STR number" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Apr 19, 2013 | Televison & Video
My tv wont turn on
power supply or horizontal section fault. in power supply rectifier may be short circuited or S.T.R may burn off.in horizontal transistor may be internally short circuited or E.H.T transformer may be open
Nov 05, 2012 | Televison & Video
In my tv fuse is blowing off immediately
Hello
If fuse blows off immediately, i means that there is a short circuit occured in your telivision. This can mainly due to some diodes or regulators inside your tv. An overvoltage, spikes, ie [sudden high rise and go low], in the supply votage in your home, could damage power supply regulator components inside your tv.
All Sony Tvs has high accuracy power regulating systems inside. It is an onboard assembly, usually take 1/4th of the area of the TV. In older Sony TVs, this section was built in with use of transistors of different types. But your tv is not so old, so its power supply system is built with an STR, an Ic meant only for power regulations. Normally it willb numbered STR S6707, STR S6703 etc; according th the working voltage of the main board, and screen size of the TV.
This STR may get shorted due to power fluctuations, or any other reasons. A I mentioned above this is an Ic look like small squuare biscut of about an inch in square, and will be black in colour.
The rectified main power supply is given to it via an SMPS transformer [Swiched Mode Transformer], and the Ic will swictch it on and off at the rate of sbout 25KHz or more, and this transformeres secondary voltage is used to power up the other part of the ciiruit board.
If the fuse is blowing as soon as the set is switched on, this Ic will be faulty [Shorted inside]. If you put an another fuse, it also will blow up due to short. It is not good to play with power supply system by doing this as it may harm to other components also.
You have done it I thinks. Here in India, we gets 220VAC as home power supply. Sony TVs used here have a fuse rateing of 250V 3.5Amps. If your household supply system voltage is also this you must put only this rated fuse. If it is 110 or 120VAC, the fuse rating may differ; and will go upto 6 to7 Amps. More than this rated fuse should not be used.
You just do one thing. Just open the back cover of the TV, locate the power regulator section, and chech whether any main rectifier diodes for leak. There may four of them. In some sony Tvs, rectifier stalks are used. Check it for leak. If thery are all good, measure the resistance across the main filter capacitor with a multimeter set in Ohms range. If the STR said above is short, the meter will give full scale deflection. Unsoder the STR and pick it out after loosing its fixing screws to the heat sink. Again check the resistance accross the main filter capacitor. It must sho a low deflection or no deflection at all. Never replace the STR with a new one as there may be some other faulty components in that section. Usually when STR fails, there are some Zener diodes, Wire wound resistor etc will also gets shrted. If you replce the STR before checking them for fault, the STR you puts in will get shorted as you swich on the set. It will take just 1/100 part of a second.
So check all the components related with power regulator system, and then only repace the regulator. Caution: Keep chlidren away from you while you open the tv. Never touch any part of the circuit board while power supply is there. Plug out from the wall socket each time you touch the printed circuit board. As your Tv screen size is 32", an approximate of 25KVDC [15,000VDC], will be present at the first anode of the picture tube while it is working. It is too dagerous to contact.
If you haven't through knoledge, skill and patience, never try to repair it. If you knows to follow its schematic digram, buy one book and follow the circuit.
Keep an adult beside you as you try to repair your set, as a precaution.
If you have any doubt, report to Fixya, they will give me alert. Ok
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No power -- bad power supply?
The fuse thats leads to the power supply on the sony receiver blows everytime i try to plug in the receiver. What makes this happen and what can i do to get the receiver going again. Model STR-DE135.
Jul 02, 2008 | Sony STR-DE135 Receiver
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
Electro Med Services...
