Question about Maytag EPIC MFW9700S Front Load Washer
Contol locked light is on cannot use machine, turned breaker off & unplugged still locked
  • cheriehygaar Jan 01, 2011
    I turned the dial to drain and spin and held the start button, nothing, my washer is a 9600SQO frontloader, I also pushed the control on button for 15 sec, nothing
    I have a 9600SQO front loader the contol locked button is on, turned dial to drain & spin, held start button for 15 sec, nothing
  • Maytag Master
  • 1,902 Answers
Hello & Welcome to FixYa
To unlock the controls press and hold the END OF CYCLE button for 15 seconds, the problem should be resolved after doing this. Please get back to me if you have any other questions.
Kevin
Posted on Jan 01, 2011
  • Maytag Master
  • 8,220 Answers
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
Remove the base panel and get the tech sheet out. Do the diagnostics.
Here is the Handy Hippy to show you how to get that base panel off.
  • Dan Webster
    Dan Webster Jan 01, 2011
    Epic Z manual unlock:
    unplug washer
    remove lower kick panel
    reach up and locate bottom of door lock switch
    grab the teardrop shaped tab
    pull gently till yall hear a click
    the door will be opened
    Would you like a copy of that service manual?
  • Dan Webster
  • 4,323 Answers
Hi
This issue is related to a shorted or loose connection on the keypad or due to control unit error.
1. Check the touchpad/LED assembly by selecting different cycles and changing the
modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touchpad/LED assembly and Central Control
Unit (CCU).
To remove the touchpad/LED assembly:
1. Unplug washer or disconnect power.
2. Disconnect touchpad/LED assembly wire harness from the CCU.
3. Remove dispenser drawer.
4. Remove left front screw that was covered by the dispenser drawer.
5. Open door, under the center of the touchpad/ LED assembly there is a notch, insert a flat
blade screwdriver in notch to release the bottom of the touchpad/LED assembly.
6. On the right hand side behind the touchpad/ LED assembly, press tab to release right
side of the touchpad/LED assembly.
7. Gently pry up and release the top of the touchpad/LED assembly. This should completely
release the entire touchpad/LED assembly.
Hope this helps... Please post back if you need more information.
Daniel
The control lock light on. Control panel not working. How do I get the contol lock suspended?
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Sep 23, 2011 | Whirlpool GHW9400 Front Load Washer
The contol panel light wont turn on. The status light says control locked
Kevin
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Contol locked light is on washer wont run
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jun 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked led indicator is on ,there no contol at all
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You dont want kids bathing in the machine, no. Pl rate me nice.
May 13, 2009 | Whirlpool GHW9100L Front Load Washer
Contol on light blinking, kitchenaide front loading automatic washer, two years old
if this is a flash fault code consult your manual to see what the code is telling you then relist the code for some more advice.
Jan 20, 2008 | KitchenAid KHWS02R Front Load Washer
Obviously there is an issue, perhaps a safety issue.
Suggest don't over-ride anything.
Check your owner's manual to see what blinking light indicates.
Nov 02, 2017 | KitchenAid Superba Architect KSCS25INSS...
Maytag EPIC MFW9700S Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
