Question about Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
The right output channel on the right side of my pmc 05 pro 4 has very low output. I can hear both right and left output channels in the headphones when I have the cue selected but when I try to monitor the master output the right output on the right side is extremely low. It also the same on the actual master output to my speakers. I've switched the input to make sure that it's not a bad RCA and it is not. It's internal in the mixer. Any suggestions?
  • Vestax Master
  • 5,603 Answers
I assume you swapped thee output leads as well as the inputs which you di mention, to verify you amps and cables...
The Vestax schematic I have is NOT your same model, but the companies often re-use circuitry. In the schematic I have it appears that the two channels go through two levels of NJM2068L op amps.
In these two levels there is both a master gain control. It is important to know whether the gain control varies the output level of the right, even if it is low. Also in this gain control area is a master balance pot which varies the ratio of the left and right and is CAPABLE of taking either channel to near zero output... IF you have that control check it for sure !!! The pot is a dual employing both an A taper and C taper which is a reverse of the A.
The right tool for troubleshooting this is an oscilloscope, but first an inspection looking for board cracks around the output and pot area is in order.
Posted on Jan 02, 2011
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Both sides of my headphones are outputting sound however music that is supposed to be left isn't outputted at all. That is, if a song has instruments playing on the left side of the track, it won&
Are you using the 1/4 inch adapter- if so- make sure the mini plug is fully seated- you should feel 2 detents as you push the plug into the adapter- if you do not, you may be bridging the tip and ring colar with one channel and because it is not seated fully, it is not contacting the other channel at all.
Also make sure the plug for the headphones is fully seated into whatever device you are listening to. you should feel the 2 detents each time.
Apr 01, 2012 | Music
Have a problem with the xp510i - left channel has no output to speaker. Tested with other speaker and cable - appears to be the mixer.
"Tested with other speaker and cable" ... you did not tell us the results of the test. If swapping the speakers and cablles still had the same dead side, it is probably the power amp for that side and not the mixer part. Take in for repair. If you had an accident of speaker cable not being plugged in fully or pulled out while operating, this pops the power amp real quick. They also just plain fail at times. Plug a set of headphones into the MONO out jack. If you can hear audio going through the unit then the mixer is OK... and the power amp on the failing side has a failure. Note the headphones will be low level and probably only one side, usually the left as this is a mono signal and headphones are normally stereo.
Apr 26, 2011 | Samson EXpedition 510i Speaker PA System
Suddenly the monitor one output jack has no sound. If I turn the Monitor one slider all the way up I can hear a very low sound with distortion. The monitor output works fine.
Make sure the appropriate channel rotary knob MON1 knob is turned up for the channels you want into MON1. ALSO test other channels if they can be sent to MON1. The MON jacks are TRS with the tip as the hot and the sleeve as resistor to ground.
Hopefully you have used good practice and have ALWAYS powered whatever you are driving from the MON1 out from the same receptacle as the PMP5000. If not, ground bounce MAY have destroyed the driver in thee PMP5000. They USUALLY don't tell you these things in the user manuals, so it is up to us electricaal engineers to educate.
FIRST plug in a set of headphones and see if sound comes out (it will only be one side and fairly low volume, usually the left). If it does, then cabling and whatever amp you have for the MON1 has a problem. I have schematics and can help you troubleshoot a bit.
Also PLEASE read the tip I have posted on here about a grounding hazard of the A channel when using Speakon to 1/4 inch cables.
Nov 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
Headphone channel is broken, outputs fuzzy, needs service
I'd try this company:http://www.wdgreenhill.com/ I had good service from them and I live in Canada. They are in Rochford Essex.
May 14, 2010 | Vestax Pmc 280 DJ Mixer
Left channel out on behinger ub2222fx-pro could use a service manual. Thanks in advance
Behringer only give the manuals to their authorized service agencies I am told.
Mixers are very symetrical and have lots of diagnostic capability from the outputs.
If you headphones work, chances are the moxer biss es are OK which probably focuses the problem on the output drivers.
Use headphones to see what jacks work... Remember that a stereo headphone will only have sound on one side for the mono jacks you test.
If your mains have a dedicated slider, one half of the slider could be bad. Usually you can tell those by a rougness as you slide them.
Feb 07, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Headphone output distorted on one side. Replacement jack?
studiospares (in london) or radioshack in USA, unscrew and get busy with a soldering iron, its not too hard, only 4 cables.
Jan 22, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How to listen to music in 1 channel and listen to another channel in the phone jack
I'm not entirely sure what you are trying to do here. Using the left/right panning capability, you can send one mix to the left output and another to the right. You can use the "pre-fade listen" to hear a channel in the headphones without effecting the output.
If you can explain in more detail what you are trying to do, I shoud be able to describe how to do it.
Dan
Jan 11, 2010 | Mackie 1202vlz3 12 Channel Mixer
Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER Logo
353 people viewed this question
Top Vestax Music Experts
Michial Gueffroy
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Vestax Music Expert? Answer questions, earn points and help others
