Question about Haier Dehumidifiers
Need a repair shop in the baltimore area to look at my dehumidifier runs but wont pull water
  • 27 Answers
It's cold outside. If the temperature is too low, the cold coils will just frost up and you won't get much water 'pulled'.
Check to see if the cold coils actually are getting cold when the unit is running and the control is set to cause the compressor to work-not just the fan.
If the coils are cold and full of frost or ice, the room is too cold for the dehumidifier to work. You'll have to raise the temperature of the room or wait for warmer weather.
If the coils never get cold, the compressor might be bad or the unit might have lost its freon.
I wonder, though, if it's just too cool and dry right now for a dehumidifier to be pulling more moisture out of the air.
Hope this helps!
Posted on Jan 01, 2011
One day, smelled like burning, then we check, no water in bucket, we know it wont work? so what we should do?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 29, 2011 | Whirlpool AD50USS Dehumidifier
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
My dehumidifier wont cool. it used to but now only hot air comes out. i need it to cool down my area desperately bad! please send your advice back ASAP! thank you!
heatman101
May 30, 2011 | Fedders A7DH45B2A Dehumidifier
FDL25P1 25-Pint Portable Dehumidifier Dehumidifier: The dehumidifier is running but is not pulling any...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 18, 2010 | Frigidaire FDL25P1 Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
Not removing water and says tank it full
I just had one giving me the somewhat the same problem. Upon taking it apart I found that the entire inside was filthy. This thing runs in a work area in my basement and sucks up all of the dirty air. When you take the water out of the dirty air you have nothing but the dirt and the water. When you mix those together you get mud which is what clogged everything up in mine.
Dehumidifiers need to be clean on the inside to run properly especially all of the fins on the condensor. You will probably have to take it apart and clean it. Concentrate on the fins and the water collection areas. Dehumidifiers remove heat from the air which causes the humidity to collect on the condensor. As it collects it turns into water droplets. Gravity pulls the water droplets into the water collection areas and that flows to your tank. There is some sort of float in your tank that lets the dehumidifier know it is full and shuts it off with some sort of switch. It does this so it does not just keep running and eventually pour water onto your floor. It sounds like your switch and/or float is stuck. Find the float and switch and manually work them to make certain they are working freely, clean if necessary.
If the dehumidifier does not remove water like it should it is probably not getting good airflow. There are ice sensors on the evaporator that tells the compressor to stop working. However the fan will still run to pull warm air across the ice so that it melts, goes into the water collection area and into your tank. Some of these ice sensors work by measuring air flow. If there is no air flow or very limited air flow the sensor will tell the compressor not to work. The fan will run again to melt the ice so that it melts and is removed. If your condensor is dirty and does not allow the air to flow, this could cause your problem.
Mar 24, 2010 | Danby DDR6588EE Dehumidifier
Unit runs but doesn't pull humidity out of room, filter clean
Possibly lost refrigerant from system- check warm air is coming out of machine. Otherwise it could be dirty filters, and not getting enough air over evaporating coil. Other than this, replacing parts is usually more expensive than buying a new dehumidifier :(
Jul 18, 2009 | Dehumidifiers
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Unusual smell
Odors are generally caused by stagnant water or chronically dirty condenser coils. 1) Unplug the unit. 2) Empty the reservoir, mop up any damp areas, and clean the coils with a brush and a garden hose. Note: You can have a dehumidifier's coils steam-cleaned at an appliance-repair or auto-repair shop, but if you do this, have the unit checked after the cleaning to be sure the electrical components haven't been disturbed. Allow to dry in a warm place for at least 24 hours.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Dehumidifiers Logo
120 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Vincent Cruz
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
