Question about Sony STR-DE545 Receiver
My reciever turns on you can hear it click on but no display lights and no sound out of speakers what could be the problem
  • Sony Master
  • 6,771 Answers
I have found in some situations the cause is in the output stage of the audio ic's, the safety circuits disable the outputs and when that happens the B+ to the display is not present. But it is possible the processor ic has failed causing all functions to be dead. One possible solution is to unplug the receiver for at least 30 minutes to see if the processor will reset. The final option is to have it checked by a professional.
Posted on Jan 01, 2011
Marantz SR 3001 won't turn on
Check for shorted speaker wires - if none found, disconnect speaker / select headphones and see if you hear music thru the headphones. If not - you may have burnt out power transistors, etc.
Jan 12, 2014 | Marantz SR3001
I have a Pioneer VSX-D510 reciever with 5 speakers and sub. The sub keeps making continual popping sounds at higher volume levels when watching movies, tv etc. Have to turn most of the way down. Also,...
Manuals help a lot.
Tell us about the speakers. Maybe they're not compatible.
As far as what to expect to hear from surrounds, that depends on the sound engineering.
Test tones for speaker setup will get it all dialed in. Page 17.
Mar 05, 2011 | Pioneer VSX-D510 Receiver
How do i turn on all 5 speakers for my yamaha rx-v463 receiver
To turn on all 5 speakers from your reciever you will want to press the audio selct button on either your remote or on the front of the unit itself. This will scroll through the different sound fields and the easiest thing to do is to look at the front right of the recievers display. While scrolling through you will see the speaker icons and all 5 channels should light up when your on the correct soundfield. Dolby digital 5.1 and all channel stereo are common soundfields that use all the speakers. It is important to remember that your surround speakers are only intended to reproduce sound effects, and not full range audio like the fronts. Of course, if it is your desire you can definately override this.
Hope this helped,
Thanks
Jan 03, 2011 | Yamaha RX-V463 Receiver
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Samsung reciever sound issues
I am having the same problem... I would like to hear from anyone with a solution or at least a reason!
Dec 29, 2009 | Samsung Audio Players & Recorders
I don't get any front display or any sound when turned on.
Do you hear any clicks? If not, the standby transformer or related circuitry is bad. If you hear 1 relay click...the audio output section is most likely the problem. The first click you hear is the main power relay...and should see display.. the second relay click is the protection circuit relay engaging to let audio to your speakers...if the second click is not heard (it should occur in 3 to 5 seconds) there are shorted output transistors or a shorted output IC trying to blow your speakers with 50 to 75 volts dc. The protection circuit monitors the speaker lines for voltage. They should always read milli-volts only...not even 1 volt.Anyway, good luck
Sep 24, 2009 | Sony STR-DE525
System turns on but only hear feedback fomr speakser no sound
do the headphones work?that means the pre amp is working.
the speaker protection is maybe activated from shorted wires on the back,there should be a click 5 to 7 seconds after turning it on.
that is the relay that connects the speakers.check the speaker a and b switch. people are not aware of this,but alot of amplifiers ADD the a and b speakers,to prevent too low an impedance from parallel wiring.unless there is 4 speakers,no sound.
May 22, 2009 | Pioneer VSX-D409
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
No sound driver
Turn the power off. Wait about 10 seconds,then power up again get close to the reciever and listen for a click-not from the speakers ,fromthe recievers itself.If you hear a click,you can assume that the power supply is ok for that cercuit.This does'nt eliminate the power supply,but it will do for now.Put the speakers close to the reciever,what you will do now is to power up the reciever while listening to the speakers with the volume off.In about 3-5 seconds you should a hear a slight click from the speakers. Try this with both speakers if you don't plug in a pair of headphones to the headphone jack and play the source . If you still no sound with headphones you at least now know that the output transistors are not the problem or the only problem.The power amp., section are defected also.Message whatever happens.
Jun 17, 2008 | Audio Players & Recorders
Sony STR-DE545 Receiver Logo
83 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
