Question about Microwave Ovens
Dishes don't get clean and detergent leaves a white coating behind. Wash arms work, detergent door closes, no gunk on the bottom filter, soap cover operates correctly, water is hot? What is left to check to fix the prob?
    Brigadier General:
  • 8,909 Answers
Dishwasher salt is missing, or rinse aid.
Posted on Jan 01, 2011
  • jaysacurly Jan 03, 2011
    rinse aid is full and functioning. don't know what dishwasher salt is?
  • specialistel Jan 03, 2011
    Dishwasher salt, softens the water to stop "Streaking" and "Chalk deposits" on the cleaned items.
EGGS SPLATTERED INTO MICROWAVE EMA301D2PS ELECTROLUX; HOW TO CLEAN IT?
Put a bowl of water with a couple of slices of lemon in it. Put it on low power (no convection) and heat the water up to a simmer. Turn off the microwave and leave the door closed for 10 minutes. Open the door and clean with dish soap and water, or for tough marks something like Comet or Mr Muscle Kitchen cleaner as all the dirt will be soft.
Dec 23, 2015 | In Microwave Ovens
Not cleaning dishes on bottom even when half empty - leaving film. using rinse aid. ran two cycles with vinegar help
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 04, 2011 | Microwave Ovens
My dishes are dirty after the wash. The glasses have small particles dried on the inside. They are upside down. How does it do that? Thanks.
Thanks for using FixYa.
An answer for your question about your dishwasher could be that your jets or spray arms are clogged.
1. Please look inside the dishwasher for obvious obstructions and turn the spray arms to make sure they move freely.
2. Now look at the bottom sprayer and at the little holes. If you see food or stuff in any of the holes, use small tweezers to remove.
3. Also look in the bottom area for items which may be blocking the water delivery hole.
4. Finally, look at the top sprayer arm. Using a flashlight, look closely for food or other particles which may be clogging the holes.
Let me know if this helps or if you have questions.
Thanks again for using FixYa,
Apr 03, 2011 | Microwave Ovens
It is an older model maching and it seems to be clogged and not cleaning the dishes..how do you unclog it
It would be helpful to know exactly what machine you have, but the bottom line is, you need to access the screen at the bottom of the machine, where the water exits into the pump. Many units have a macerator blade in front of the screen that chops up large particles of food so that they will pass through the screen. The blade is attached to the same shaft as the pump, which both supplies the high pressure water to wash dishes and pumps out the dirty water at the end of the cycle, and if there are small hard particles, such as bits of bone, plastic or broken glass in there, they can jam the blade so that the pump does not pump properly. You will need to remove the dish racks whatever covers, etc., are on the bottom inside the machine to get at the screen and/or macerator.
Mar 18, 2011 | Microwave Ovens
Electrolux oven door strained and wont close properly
Don't try to run a microwave oven with a bad door. At a minimum, you probably need to replace the door hinge plates. Unplug the oven and remove the top/bottom cover. Study the hinges and door to see how they come apart.
When you have the door back on and adjusted so it closes flat against the frame all around, take it to an appliance dealer who sells microwave ovens (you can leave the screws out of the cover and take them along in a plastic bag or other container). Have the service tech check for microwave leakage. If it is clean, you can fasten the cover and put the oven back in service. If you have leakage around the door, you may have to readjust the hinges, or the door itself is warped and must be replaced.
Mar 12, 2011 | Microwave Ovens
Hello I have an Inglis Soundblock II (Pretty standard) dishwasher. We have been watching it very carefull sincde our dishes stopped getting clean. All parts of the cycle seem to run well Except: There is...
How about the water inlet electrovalves, are they sticking maybe? Is there good pressure to the water inlet electrovalves from the house plumbing?
Apr 20, 2017 | Microwave Ovens
I have a whirlpool DU940pwkb1 dishwasher that stopped. The dishes are clean and rinsed. There still is water in the bottom of the dishwasher. There are no lights on and now none of the buttons work.. Dead...
Your thermal fuse is probably bad and must be replaced.
Copy and paste this link for the fuse located in the control panel.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186
Jan 08, 2011 | Microwave Ovens
Dishes are not getting clean particularly in the upper rack. The soap dispenser opens properly but the soap was still there. The washer seems to fill properly and it sounds normal. The dishwasher goes...
Make and model?Is the water hot enough? Is this a new problem? Is all of the detergent still in the dispenser or do you use detergent both in the washer and the dispenser? Please reply to this inquiry for more help. Do you have the manual?
Jan 07, 2011 | Microwave Ovens
Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker
Sep 30, 2010 | Microwave Ovens
SERVICE STICKER LEAVES MARK ON FRONT DOOR OF MICROWAVE
if you spray wd 40 or a light oil on a rag and work it into the glue this will break down the glue and make it easier to clean up.
Hope that helps...
Lbcoaster
Dec 29, 2008 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
