Question about Ridgid 12 Volt Cordless 3/8 In. Drill
My 12 volt Ridgid drill just quit alltogether. I know it,s not the battery or charger as I have an identical drill and it works just fine. This drill takes the small cartridge type battery. Any suggestions. I love this drill and use it a lot.( hobby woodworking)
  • Jason Roy Sep 21, 2017
    Ridgid is a great tool. Wish I had gotten them 2 years ago. I really like the lightweight without loss of performance
  • 312 Answers
To start, I assume you took the "good" battery from the working drill and tested the inoperative drill.
Good for doing that.
The other causes I know of in Drills that turn them into paper weights are as follows:
1 Worn Brushed: You can attempt to test this by squeezing the assumed good trigger button and
Taping the drill or lightly banging it on a bench top or something else. If it is brushes, it will often but no necessarily all the time, start to run for a moment, or just running. Since you use the drill and "use it a lot" That will be the first thing I would look for.
2 Trigger Button.
I would bring it to a tool service place or send it back to Ridgid. Try this link
http://www.ridgid.com/Tools/Technical-Services/index.htm
Hope this helps, Happy New Year
Mark
Posted on Jan 01, 2011
My ridgid 24 volt battery wont charge or the battery charger doesn't work how do i test it
there are points where the battery connects to the charger. these points can be tested with a DVOM (digital volt ohm meter- and it can just be a volt ohm meter, it doesn't have to be digital ) - your meter should read voltage when checking across the points. Now if it has a button to turn it on and you turn it on and measure nothing, you're going to have to open the charger up... there is a lot more to this testing... next time, include model number for the charger please
Oct 25, 2013 | Ridgid Drills
Drill shuts off
Yes, it's tripping on over temp. There is a thermal protection inside the motor. Try to not press so hard so the motor doesn't pull so hard. Let the drill do the work, and let it run at the set RPM. You will get more life from the battery and the drill motor.
Sep 03, 2009 | Ridgid 12 Volt Cordless 3/8 In. Drill
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
Jun 22, 2009 | Ryobi Multi-Volt Battery Charger
MAKITA DC1290A CHARGER PROBLEM
Makita generally does not provide a schematic for the charger wiring. The only parts that are usually replaceable are the cord and housings and possibly a fuse. If this is an older charger I would look for a "cold solder joint" I fixed quite a few for this and one component breaking loose. I dont know if Makitausa website can help or not. What volt is this charger, I have a couple in my garage that I can look at also
Jan 19, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Panasonic EY0110 Charger
Use a volt meter attatch to the contacts and see if you are getting 12 volts .If so then your charger should be okay
Nov 26, 2008 | Panasonic EY6409NQKW 12 - Volt Drill/...
Test charger ey 0110
TAKE TEST METER ON DC VOLTAGE AND PLACE ON THE TERMINAL IN CHARGER SHOULD READ 12 VOLTS ON 2 OF THE TERMINALS IF YOU DON'T HAVE A METER YOU CAN USE A TAIL LAMP SOCKET AND BULB OR ANY DC LAMP OF A 12 VOLT RATING
Charger for 12 volts 7 amp battery smf
you need to go to a **** smith store and bye a kit to do this cheers peter
Apr 18, 2008 | Ryobi Multi-Volt Battery Charger
Ridgid 12 Volt Cordless 3/8 In. Drill  Logo
372 people viewed this question
Top Ridgid Drills Experts
Tim Whalen
Bill Boyd
Are you a Ridgid Drill Expert? Answer questions, earn points and help others
