Question about Sony STR-DB940 Receiver
I want to program my new Logitech Harmony One for the [2-channel], [AFD], and the various sound field functions, but I have been unable to record those from the RM-LJ304 remote that came with the receiver. The Logitech site has support for all other functions of the STR-DB940 receiver (that I have tried, anyway), but nothing for these. There are separate buttons for [2-channel] and [AFD] on the front panel, so it would seem reasonable that there are remote codes (or possibly sequences) for these, but I haven't been able to com up with them. Has anyone managed to do this??
Hello did you find any solution ?
I have exactly the sams issue with the harmony one and the STR-DB940 and I don't find the solution till now
Posted on Dec 08, 2011
Dav dz750k
Check your center channel. Most dialogue is routed to the center channel in surround.
Jul 24, 2013 | Audio Players & Recorders
Program remote to replace all remotes
Hi, yes of course it is possible! First off, you have to make sure that your Dish device it set on remote address 1 in order for it to be controlled by the Harmony. Then, once you add the device to your Harmony account, if there are any functions that are missing, you can learn them right from the original remote .
Adding a device:
1. In the software, clcik 'Add Device'
2. Follow the on screen instructions.
Learning a command:
1. In the software, click 'Learn IR' next to the icon for your Dish device.
2. Go down to the bottom of the page where it says 'Learn a new command'
3. Type in a name for your command, and click 'Learn'
4. Follow the on-screen instructions.
Hope that helps you get this set up right!
Mar 17, 2010 | Logitech Harmony 700 LCD Remote Control
Harmony 520 no sound control for tv
I can help you program your Logitech Harmony 520 remote for your TV.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Sep 28, 2009 | Logitech Harmony 520 LCD Remote Control
How to program favorite channels in the harmony 520 remote by logitech
The Harmony 520 remote does not support Favorite Channels.
However, you can set this up by creating a sequence to send the number commands for a specific channel, then map the sequence to a button. See the following link for a walk through of how to do that.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9185
The article is for a Harmony 1000, but it is the same process for any remote that supports sequences.
Sep 12, 2009 | Logitech Harmony 520 LCD Remote Control
I am trying to set up the "favorite channels" function on my harmony 880 remote and I keep getting an error message that the channel numbers are not valid. On my TV, for example, NBC is 05-1 (that's what I...
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Mar 24, 2009 | Logitech Harmony 880 Universal Remote...
Harmony 890 will no longer operate the tv, dvr,or sound
I had a similar issue and only needed to "re-configue" the remote... Basically, just try plugging it back into a USB cord ( connected to your computer) and go to the original programming home page and click the "Update button." It will re-program your remote as if it was new.. Over time your Harmony may lose or forget the frequency of your various components. This happened to me. Also, make sure the remote has a full charge while you're programming it. Give it a try !
Mar 18, 2009 | Logitech Harmony 890 Universal Remote
Need a manual to know how to use the various menus on the remote
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
Harmony 890 Manual Download
Harmony MAC Software Download
Jan 23, 2009 | Logitech Harmony 890 Universal Remote
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
I recommend resetting it up with your components to get rid of the two channel problem.
I hope that helps.
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech
You need to be more specific about your problem.  Have you already programmed your Harmony Remote on the internet?  Does it control all other functions (such as changing channels) on your TV?
Do you have any other components connected (such as a Home Theater Receiver) that might be a source of sound?
Please post more details, and I may be able to help.
Jan 20, 2008 | Logitech Harmony 880 LCD Remote Control
Sony STR-DB940 Receiver Logo
339 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
