The domestic fuse blew in this house and the PC doeesn't work, I have changed the 13 amp fuse with no success, is there a trip in the PC? The computer is a Presario SR1000 desktop
    Scholar:
  • 174 Answers
If while switching your PC on the fuse blows means you have to change the power supply of the computer - PowerIC short in the powerunit
Posted on Jul 08, 2008
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
I blew the fus/curcuit trying to change the light bulb in the dryer. Now it wont run .
Check the fuses inside the machine. If it is a European machine, there is usually a 13 amp fuse in the plug.
Jan 16, 2014 | Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
The wires come off the pump so i put them back on now i got nothing working
Also,
please note that all electrical wiring and installation details given on diydata.com is for information purposes only. From 1st January 2005, the Building Regulations Part P requires, in England and Wales, that only certified persons can carryout electrical installation work, or the work must be certified upon completion - see this page for more details.
Ring circuit
(1) The ordinary wall sockets around the house are normally connected to a ring circuit (also referred to as a ring main). The ring circuits of a domestic property supply the socket outlets and fixed appliances in the premises.
(2) The 'ring' is formed by the cable going from the consumer unit to the first socket, then on to the second socket and then the next socket etc. until the cable returns to the consumer unit. This means (in simple terms) that every socket on the ring circuit has two cable routes back to the supply. The cable of the ring circuit consists of a red (live) wire, a black (neutral) wire and a bare copper earth wire, all three being enclosed by an outer PVC sheathing. The cable used in domestic ring circuits is either 2.5sq mm or 4.0sq mm twin core and earth, these are rated (in free air) at 24amps or 32amps respectively.
(3) Each ring circuit is protected by a 32 amp fuse or trip fitted in the consumer unit. Modern installations incorporate a Residual Current Device (RCD) before the consumer unit which trips the whole system off if a fault is detected.
(4) In older houses the cabling for ring circuits (and other circuits) may be fed through the wall cavity with the cables coming into the back of the wall mounted socket. This is unacceptable in new premises and extensions. It is now considered that cables within the cavity may become wet causing the insulation of the cable to break down and moisture running down the cable into the socket. When rewiring older houses, new cables should not be run through the cavity, they should be run through new ducting embedded in the inner wall surfaces or under floorboards.
(5) A ring circuit is considered to be rated at 30amps (7200 watts). A ring may serve up to 100 m sq of floor area and, in theory, may have any number of sockets outlets or fused connection units connected to it. With each socket outlet is normally rated at 13 amps, as a 'rule of thumb', they are limited to under twenty outlets, it is unlikely that the variety of domestic appliances being used at any one time will exceed 30amps. The length of cable used in a ring circuit is limited to 50 metres for circuits protected by an MCB. The sockets are normally mounted flush with the wall although surface mounted boxes are often easier to fit when sockets are added to the circuit. .
(6) High power electrical appliances (such as cookers, showers etc.) should not be connected to a ring main even if they use less current that the 30 amp rating of the ring circuit. Connection of such appliances will reduce the number of other appliances that can be use simultaneously and will lead to nuisance trips at the consumer unit.
(7) It is advisable to have at least two ring circuit in all premises, in multi floor houses, one for each floor. The kitchen may have a large number of electrical appliances so a separate ring circuit for the kitchen may also worthwhile, this has the added benefit that a freezer will not be affected if there is a fault elsewhere. A single ring circuit should serve a floor area no greater than 100sq m (or 120sq yd).
(8) In the UK, plugs used on a modern ring circuit have square pins and each plug is fitted with either 3 or 13 amp fuses. The correct fuse should always be fitted to suit the appliance, 3 amp fuses for appliances rated up to 750 watts, (lamps and clock radios etc.) - 13amp fuses for larger appliances up to 3000 watts.
(9) Spur extensions can be connected to the ring circuit. A spur is a socket connected into the ring by a single cable run so the socket does not have the full benefit of two cable routes to the consumer unit. Spurs are often used when a socket is added, it is easier to connect using a single cable rather than extending the ring circuit to include the new socket. A spur extension can be connected to the ring circuit provided that it supplies only 13 amp socket outlet (although that can be a double socket outlet) or one fixed appliance. Over the whole ring, the total number of spurs must not exceed the number of socket outlets directly on the main ring. No more than two separate spurs may be connected from each outlet on the ring.
Removal of the front of a wall socket will give an indication of the circuit connected to it:
A single cable connected to the terminals indicates that it is an existing spur.
Two cables may indicate either that it is on a main ring circuit OR that it is a spur with another spur connected to it. This is not a recognised configuration but possible if both spur sockets are single sockets.
Three or four cables normally indicate a socket on a main ring circuit with one or two spurs running from it.
If the wiring has been changed by a previous diy'er, it may be possible to identify any added cables and then deduce the original circuit.
Ring circuit fused outlet units
Where connection to a fixed appliance is required, a fused outlet unit may be fitted to the wall (rather than a plug socket) and connected into the ring main. These outlets require the correct fuse rating for the appliance and are connected to the appliance by a cable or flex. The outlet may be switched or unswitched and may be fitted with an indicator light to show when the supply is connected.
Where a flex is taken to a heater of any sort (e.g. night store heater) the flex must be of a special 'high temperature' type suitable for the elevated temperatures encountered. Use of ordinary flex will result in the insulation breaking down causing the flex to become dangerous.
A clock outlet is a similar type of unit, but with a small fuse fitted in a special plug connected to the flex. The plug may be retained in the socket by a screw or knurled thumbscrew. Though called a clock outlet, they are also suitable for other small low current appliances such as extractor fan units, door bells.
High Power circuits.
Within domestic premises, there may be a number of high wattage appliances, the most common being an electric cooker, immersion heater and electric shower. Each of these appliances should be connected to the consumer unit using a dedicated fuse/trip and cable run. The installation instructions for the appliance should detail the wattage of the appliance (which will also normally be shown somewhere on the appliance), the amperage of the fuse/trip and the size of cable required. Any switches on these circuits must also be of a suitable current rating. Source(s): http://www.diydata.com/planning/ring_mai...
May 17, 2011 | Hoover Washing Machines
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
Where is the 30 amp fuses located?
in your fuse panel for the house. try turning the breaker off then back on. even though the breaker doesnt look tripped , one side could be tripped and not trip the whole breaker. If you have 2 thirty amp screw in fuses in your panel just replace them both.
Dec 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
We replaced our thermastat with a new one and it would notwork. replaced with the old one that had worked and now it does not work. is there a reset
Common problem with changing a tst. You blew the fuse in the furnace or Air Handler or you burnt up the transformer in the furnace or Air Handler. Hopefully you just blew a fuse. A 5 amp automotive fuse will fir back in the holder. Most all companies use a auto fuse 3 to 5 amp. Some have abreaker on the transformer. If you burnt out transformer you have yo replace it. Not hard to do Most of the time they 40 VA transformers. Go to HVAC supply house and buy one about 15.00
Dec 05, 2009 | Refrigerators
Crate amp blew a house fuse and stopped working. pilot light still works and I can get a distorted signal through the headphones if I play a guitar very loudly through it.
When a piece of equipment causes a fuse to blow or a breaker to trip, it normally means something in the equipment's circuit was shorted. Either because of heat, moisture, a loose screw, loose wire, loose part, a bug, etc. For safety reasons, don't plug it back in and take it to a repair shop.
Hope this helps!
Jun 04, 2009 | Crate Music
Zanussi frost free fridge freezer
if problem happens every fewhours it is possibly the defrost element
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
