Question about Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250
How to replace oil pump in Stihl 018 chainsaw.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 344 Answers
The oiler is set in place to a depth premeasured and tough to duplicate without the proper tool. If you use a proper sized bolt 5mm about 200mm long. After threading in till it stops mark the depth with a marker. pull the bolt out and the oiler will be on the end of the bolt.
thread the new oiler on and reverse the procedure.
My recommendation is to see a local service dealer like www.arcolawn.com and purchase the speciality tools:
21 Assembly tool 1123 890 2200 Removing oil pump
22 - Puller 1130 893 1400
23 - Installer 1130 893 1500
After saying all that I would tell you that a dull chain is the number one cause of "oiler problems" because a dull chain will over heat and make it seem as if the chain has no oil.
Good luck
Joe
vote this up if it helped.
Posted on Feb 12, 2011
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How do I disassemble bar oiler and tank on unidentified chainsaw?
Stihl 017& 018 repair to bar oiling system, showing oil pump ...
? 12:36
www.youtube.com/watch?v=lJFAmUz49DQ
Jan 1, 2014 - Uploaded by Andy Reynolds A common fault with the Stihl 017 and 018 is low or no oil getting ... 018 repair to bar oiling system, showing oil pump feed andoil tank removal.
Sep 30, 2015 | Garden
How to replace oil pump in stihl 031 chainsaw ?
Remove the worm, sealing ring and washer, loosen the pan head screws on the oil pump and replace. Check if the gasket is re-usable.
Jun 11, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Oil pump does not work
Checlk the oil worm gear is driving the pump. If this isnt the problem then try the following:-
The type of oil pump fitted to these models is prone to getting blocked.
Remove the oil pump. The gear on top should turn freely, give the pump a clean and clean the oil pipe to the tank by removing the oil cap and blowing through with an air line. If the oil in the tank contains alot of dirt, empty/clean and replace. The filter on the oil is an open plastic cage type and often will draw large sawdust particles through it. Easily rectified tho.
Aug 24, 2012 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Have a stihl MS180 and it is not pumping any oil out of the hole and slot that makes contact with the bar. How do you remove the oil pump?
To remove the oil pump you need the following:
Assembly tool 1123 890 2200 Removing oil pump Puller 1130 893 1400 Installer 1130 893 1500
I would recommend trying to clean out the oiler first.
Please comment on this and tell us what type of oil you were using. There are rumors of wrong oil clogging or wearing the oilers. Was it used motor oil? Thanks Joe
Feb 16, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How do I replace the oil pump on a Stihl MS170 chainsaw
The oil pump is pressed in from the bottom. There is a special bolt and bracket to make sure the pump is set to the right depth. Your local dealer should bea able to get the tool for you but it will be cheaper to have the shop do the work.
PS it is more common on this saw to have a dull chain act like it is not getting enough oil than to have a bad oiler.
I am gold certified and have been doing repairs since before the ms series. I have only replaced two oilers in that time.
Good luck
JOE
www.arcolawn.com
Dec 16, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Bar not recieving oil
The problem is related to the internal oil pump. The followings are the possibilities:
  • Clogged line from the oil reservoir to the pump.
  • Clogged line between the oil pump and the chainsaw bar orifice.
  • Faulty oil pump itself (common in well used/old device).
Hope it helps.
Jul 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
May 09, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250 Logo
2,326 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
