Question about Banner Faucets Castille 950 Series Widespread Bathroom Faucet...
I installed two banner bathroom faucets but this one is different...there are additional water connectors...there is a Y-connector in the middle and T-connectors on the hot and cold side. This will not go into the holes in bathroom sink. Installation paper says BP-01, BP-02, BP-03...the card board holding the faucet has "950" on it. What the heck? This is definitely not a regular bathroom faucet. Thanks...
  • 37 Answers
SOURCE: tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Posted on Nov 09, 2008
  • 297 Answers
SOURCE: I have a Castille collection Banner kitchen
you may have the stem in backwards,flip in around and see if this works,sometimes they only go in one way to work right.
Posted on Jul 22, 2009
Testimonial: "I had the plastic piece in wrong. Thanks."
  • 18 Answers
SOURCE: drips when off
YES, HOME DEPOT... THE EMPLOYEES MIGHT NOT HELP YOU BUT THERE IS A FAUCET CARTRIDGE GUIDE THAT WILL HELP YOU FIND YOUR EXACT ONE, AND IF THEY DON'T HAVE IT IN STOCK IT WILL ONLY TAKE A COUPLE DAYS TO GET IN. TRUST ME I USE TO BE A PLUMBING EXPERT AT HOME DEPOT.
Posted on Dec 29, 2009
  • 2841 Answers
SOURCE: How can I keep the handle from getting loose on my
Install a lock washer on it. Get one that fits perfectly.
Posted on Oct 14, 2010
  • 3640 Answers
SOURCE: we installed the tub faucet
it is due to the rubber seals on back of valve stems, they are not seating right to stop complete flow of water. just remove stem and replace. if it still leaks, the valve seat may need be replaced. most just turn out to replace ( with a square tool ) found at most hardware stores etc. good-day !
Posted on Aug 26, 2011
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
The braided hot and cold faucet hoses are too short to connect to the plumbing. Are there connectors that can be purchased?
Braided supply lines are available in a variety of lengths. Also, if practical, consider extending the stub outs to allow connection to the braided lines.
Jan 26, 2016 | Grohe Bathroom Faucet Eurosmart Kit Chrome
How do I take it apart
faucet should have allen screw hole behind or under, just look around and you will find it. they unscrew with allen wrench
May 07, 2012 | Banner Faucets Castille 600 Series Brushed...
Faucet leaks when water is turned on at the spout base. I took the set screw out of the back but can,t remove it to access the orings or seals
better turn off the main line first, screw the ring again putting some extra pressure because usually rings are tighten so hard.you have to replace the base of the faucet.
Jun 22, 2011 | Banner Faucets Castille 700 Vintage Series...
WHEN MY SHOWER IS TURNED ON THE WATER ALSO FLOWS OUT OF THE FAUCET. HOW DO I TAKE OUT THE STEM TO CHANGE THE SEALS?
The seal is not a 100% seal, but to access there are two types, one type the tub faucet screws on and the other style is retained by an allen set screw. if you have the set screw type, you will notice a slot on the underside of the faucet, at the tub wall end, look up in there. If you see an allen, loosen it and pull the faucet straight off. if no slot or allen, unscrew the entire faucet, counter clockwise (top to the left, for those digital clock people...).
Nov 15, 2010 | Banner Faucets Castille 600 Series Brushed...
I have a glacier bay 7032e-b6104 two handle bath room faucet. i just finished installing and water is leaking underneath from the middle of the three holes where the lift rod is. what's wrong??? tony
Sounds like you have a defective faucet. I'm guessing this is a new faucet and there shouldn't be any water leaking from between the faucet and the counter top. All the fitting above the counter top are factory fittings.
The only possibility I can think of is that if you didn't use a back up wrench when you installed it and you twisted the factory installed lines too far while tightening the water supply line to the faucet, you could have broken a weld on the faucets supply line where it is connected inside the faucet.
Sep 28, 2010 | Home
Drips when off on hot water side, not sure if this faucet has replacement cartridge.
Oct 16, 2009 | Banner Faucets Castille 600 Series Brushed...
Kitchen Faucet Replacement
Option 1 ; Cap off the sprayer.  Option 2 ; Relocate the air gap as high as possible under the sink but then you have no drain under it in case it backflows (it is really a vacuum breaker ,  one way check valve) Option 3: Take back the faucet and get one of those that the spout is also the sprayer.
Jan 30, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Banner Faucets Castille 950 Series Widespread Bathroom Faucet... Logo
80 people viewed this question
Top Banner Plumbing Experts
Mike
vince
Tom Chichester
Are you a Banner Plumbing Expert? Answer questions, earn points and help others
