Question about Pro Series Thermasol Steamshower Generator Pro500
I am also having the same ERR5 message on my Thermasol PRO Elite control. I have reset the power and tried to run PowerFlush (PFLU) and the unit will go back to ERR5 message. Is there a way to do a manual power flush on my PRO 500 unit? Is there a way to check the float valve? I would like to try these methods before shipping back to Thermasol. This unit has only been used 20 times.
Light flashing no steam
Please call Thermasol tech support at 800-776-0711 and our techs will gladly help you out.
Jul 06, 2010 | Thermasol Steam Bath Generators - Ambiance...
TIML light is on and nothing works
Please contact Thermasol tech support at 800-776-0711 and our techs can help you get your unit running if you call will model and serial number will be very helpful.
May 21, 2010 | Thermasol Steam Bath Generators - Ambiance...
TTMPL code showing on my Signature series control panel. ???
I have a Thermasol steam generator which had the error code TTMPL and it had to be replaced by the manufacturer. From memory, the error code might stand for "tank temperature monitor pressure low" or something similar. As an aside, the replacement generator just started to show the same error message -- so now I'm two for two -- and not entirely happy.
Jan 16, 2010 | Thermasol Steam Bath Generators - Ambiance...
Hi, i have a new pro from thermasol steam gen.
Hello. Your thermasol pro is an excellent product. I am going to give you a link to the Thermasol Troubleshooters guide which will allow you to go step by step through all of the possible issues. And then, if you are still having problems with your Thermasol it will give you a direct phone number to call Thermasol.
http://www.thermasol.com/images/pdfs/81110.pdf
Regards, and Happy New Year. Enjoy your steam bath! Joe
Dec 31, 2009 | Hammering
Power flush problems Pro 240 -locked out at 1000hrs
This is a communication error please contact Thermasol tech support at 800-776-0711 and we can help you out.
Dec 19, 2009 | Thermasol Steam Bath Generators - Ambiance...
ThermaSol, Elite - Error 5, can this be corrected without a service call? How?
look in the ubser manual. it should tell you what the error is how to reset it.
Nov 01, 2009 | Thermasol Elite Control Package
System locked out
call 800 776 0711 ask for tech support they will help you.
Mar 21, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol Pro 150 - 25094. Doesn't work. I have a very simple controller. Just a gib gray button and four other led lights near the 15 , 30, 45, and 60 lights to set the time. I think I need to do the auto...
yes thats correct or if you have manuel flush at the genrator there is a ball valve. open for minutes then close and run generator for thirty minutes without anyone in the shower.
Mar 12, 2009 | Thermasol Steam Bath Generators - Ambiance...
Thermasol Error 5
call tech department 800 776 0711
Jan 16, 2009 | Thermasol Steamshower Generator AF Series...
Pro Series Thermasol Steamshower Generator   Pro500 Logo
75 people viewed this question
Top Pro Series Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Pro Series Electrical Supply Expert? Answer questions, earn points and help others
