Question about Office Depot Ativa DQ60M Shredder
Ativa MD460 paper shredder: misalignment light is on
SOURCE: I have an Ativa MD 460c paper shredder that reads
I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had overheated. The temperature light did not come on. I wait for over 30 minutes and tried using it again. I was able to shred a couple of sheets of paper and it stopped again. The next morning I couldn't get it to work at all. The green ready light is on but the shredder will not start. I can't tell if anything is stuck in it. How do I getting running?
Posted on Jul 24, 2011
  • 579 Answers
SOURCE: ativa shredder
Pull out as much of the paper as possible. Then spray some window cleaner or similar on whats left to soften and disolve it.
Posted on Dec 31, 2007
macrule413
SOURCE: Ativa SPL 1506X not working
I had the same "click" noise when trying to shred. I had a Staples replacement guarantee (extended warranty) so I called them up and described the issue. They are sending me a gift card for the purchase amount. Seeing as they did not want the original unit back I decided to take it apart to see if I could find the problem. I did not find an issue with the gear as the other user stated but I did notice a burn mark on the circuit board just under the relay (which could make a click noise) I removed and inspected the relay (desoldered), but I could not see anything wrong with it so I re-soldered it back onto the board and re-soldered (re-flowed) all of the other connections just in case there was a cracked joint. Upon testing the shredder still has the same "click" sound. My guess is there is a faulty device on the circuit board such as a resistor or relay. To sum it up, to repair this particular issue you will be unable to implement a "simple" fix and it would realistically require either a new circuit board or a whole new shredder.
Posted on Jun 22, 2008
splintellz1
  • 37 Answers
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Posted on Jul 03, 2009
SOURCE: Shredder won't turn on
I was using my Ativa DX180D and it was working fine. It just stopped and there was no power. I have tried all the plugs in the house but still not coming on. The basket is on properly and you can hear the click of the switch when you plsce the top on the basket. Any suggestions?
Posted on Sep 01, 2009
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
Activa MD460 shredder misaligned?
they are not made to shred credit cards .
Jan 10, 2016 | Shredder Office Equipment & Supplies
Just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help solve problem?
The misalignment message is about the catch bin and the shredder! NOT THE TEETH!
Check to make sure the shredder is properly placed on the catch bin. There is a built in safetymechanism in the Ativa MD460. When the shredder is replaced "backwards" the safety pin is not tripped.
Look for a curve in the lip on the back of the shredder and align it with the bin. Worse case, just pick up the heavy shredder top, turn the unit around 180 degrees and put back down. My light came onimmediately.
Jun 16, 2011 | Office Equipment & Supplies
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
Sep 08, 2010 | Fellowes DM8C Cross-Cut Shredder
I have an Ativa AT120DC. It won't operate
I have an Ativa AT120DC Shredder. When it is switched to auto there is dim green light and it doesn't start. If I feed paper in it makes no difference. For some time it always started up when you switched it to auto and didn't wait for paper to be fed through. If you remove the basket the Door Open light comes on. can you help?
Mar 18, 2010 | Office Equipment & Supplies
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
Shredder runs continuously in AUTO position. It appears to use a photoelectric sensor for AUTO activation. I cleaned the window once with a swab and windex. It worked for a few days but is doing it again...
There are three reasons why:
1. paper particles or oil are still causing the optics to think you are inserting paper. Remove cover and clean thoroughly!
2. Optics are misaligned.
3. Optics are defective.
Feb 22, 2009 | Office Depot Ativa DQ60M Shredder
Ativa shredder
Dec 29, 2007 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa  DQ60M Shredder Logo
1,637 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
