Question about Video Game Consoles & Games
PS3 Yobo 2.4G Wireless Controller how do i set it up to work on my ps3?
3 Suggested Answers
SOURCE: How to set up yobo controllers for ps3
I just bought a used one today and took me a little while to get it to work. Plug the USB receiver in and turn on the PS3. Press the Mode button and the lights will flash repeatedly at a fast rate (it's searching for the receiver). When it finds the USB receiver, the lights will still flash, but slower than before. When they're doing this, press the mode button again, and that should be all that you have to do. You can also plug the receiver in USB slot one, the charge cable in slot 2, and do the steps to set it up to make it work while charging. (I tried taking the receiver out while charging, and the lights started flashing again so I guess the USB receiver has to be in at all times)
Posted on Mar 07, 2009
jasper1and
1. Power on pS3 Console
2. Turn the game pad switch on. Then press Home button, the 4 LED indicators are flashing simultaneously but slowly
3. Press select plus L3 until the 4 led indicators are flashing quickly
4. Insert the receiver to PS3 console the 4 led indicators are flashing slowly again
5. Press home for connection then the port indicator LED turns to stable and you can start to play
Remarks: Please follow step 2-5 if you are using the controller for the first time. .. for succeeding usage ,after inserting the receiver to the ps3 console, press home button, the controller can automatically be connected.
Posted on Mar 16, 2011
Hi eveyone i have a ps3 and a Logitech wireless controller but won't connect to the ps3 please help
If there is a USB cable /charging port plug into PS3. If this doesn't have a USB cable /charging cable using your other ps3 controller turn ps3 on, scroll over to the settings, manage blue tooth accessories, turn controller on in discovery mode , and follow steps on screen to pair your PS3 and controller
Aug 11, 2014 | Video Game Consoles & Games
Tip
How to use a ps3 wireless controller.
<span>Ensure your playstation 3 is properly set up and connected to Plug the power cord for the PS3 wireless controller into one of the usb ports on the front of the PlayStation 3.<span><br /><br /></span><span>Plug the power cord for the PS3 wireless controller into one of the USB ports on the front of the PlayStation 3.<span><br />Plug the other end of the power cord into the access port on the top of your wireless controller.Allow the wireless controller to charge, leaving it plugged into the PlayStation 3 undisturbed for several hours to gain a full charge.Disconnect the PS3 wireless controller from the power cord. Press the PS button to start up the PlayStation 3. The PS button is in the middle of the controller. It is clear and displays the PlayStation logo of a letter P and a letter S molded together into one shape.Use the wireless controller to control the PlayStation 3, exactly as you would have with a corded controller for earlier PlayStations.<br /><span><br /><br /></span></span></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
How do i connect my arsenal ps3 controller to my ps3
on the back of the ps3 bluetooth controler there a tiny whole ,put a paper clip to reset controller . when lights are of go to ps3 hold down select and ps3 button at sametime . then horizantily hold the start button. this worked for arsenal ps3 bluetooth controller dont no about original ps3 controller
Aug 01, 2012 | Arsenal Gaming Video Game Consoles & Games
My PS3 wireless controller works fine, except for the fact the it has a delayed reaction to every movement I make it do. If I move the joy-stick left 1.5 seconds later the same appears on the television....
It sounds to me like there is a noteable delay due to a combination of things: your Bluetooth wireless controler (primary reason), and the cable connection from your PS3 to your TV. Now, to determine what the problem is specifically, you'll need to check a few things:
1. Make sure your PS3 is updated to the latest software
2. Check to make sure your cable connections from your PS3 to your TV are firmly in place. I personally have noticed that I got delayed reactions when my HDMI cable was not firmly secured to my HD TV. Weird, but as soon as I unplugged and re-plugged in the cable at both the TV end and the PS3 end, it cleared things up for me. If that does NOT work (btw, this can also be the case if you use a composite or component set up too).
3. Check to make sure that your PS3 controller is fully charged. Controllers that are partially charged occasionally do demonstrate really weird results, like the delay you're talking about. So, make sure that your PS3 controller is fully charged.
4. If the controller is fully charged AND your PS3 to TV cable is plugged in properly, then try to plug the USB cable to connect your PS3 controller to your PS3. Sometimes, for reasons I don't know about yet, this could solve the delay problem.
Dec 26, 2010 | Sony Wireless Controller for PlayStation 3
My ps3 will not recognize any wireless controllers or blue tooth devices. My Ps3 BD controller, headset and six-axis will only work connected via USB. I tried the reset buttons on the six-axis but does...
Did they connect before and now won't or are these new bluetooth set up connections? If new connections:
  1. In the XMB™ home menu, go to [Settings] > [Accessory Settings].
  2. Select the "Manage Bluetooth® Devices" option to register (or "pair") a Bluetooth-compatible device with the PS3.
Dec 03, 2017 | Sony Wireless Controller for PS3
My yobo ps3 controller will not connect to the receiver
You need to change out the battery in this, I feel it may have a dead cell in it thus causing this not to act correctly.
Let me know if you have any questions ether way.
please be considerate to leave some feedback and ratings before you leave, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2010 | YOBO FC Game Console
Its a big ben wireless controller with no usb how do i connect it to my ps3
plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
Jan 18, 2010 | Sony Wireless Controller for PS3
PS3 wireless battery operated controller, doesn't have the option of USB cable, will not pair with PS3 console?
  1. connect your controller to the PS3 with the controller charger cable (not original, nor pairing, only charging), then turn on the ps3 followed by controller (had a using controller on and assigned controller one , automatically)
  2. i used a pencil, and while all lights blinking, poked the small hole near front, L2, and on back
  3. it should now flash 2 time, and only 2,
Play Station 3 wireless controller will not ''link'' to PS3
Play Station 3 wireless (Intec) controller will not ''link'' to PS3 Console
Apr 25, 2009 | Sony Wireless Controller for PS3
Jan 11, 2009 | YOBO FC Game Console
Video Game Consoles & Games Logo
51 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
