Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
Need part # 8rk4b10003800 Ge profile Dual fuel
How do I remove the cooktop from a GE Profile Dual Fuel J2S968SHSS? I need to replace the Spark Module. Where is that located? I already replaced the wiring harness but cannot get the cooktop to re
Check in the control panel. GE sometimes puts the spark module up in the control panel. I would look there first. Sometimes they put it in the side panel.
Nov 20, 2014 | GE Kitchen Ranges
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
-AGK
Apr 17, 2011 | GE Profile JGSP44 Dual Fuel (Electric and...
M y dual fuel GE oven has no display showing it just went blank, but when you open the oven door the light goes on
I had the same problem as devlin50 with my GE duel fuel 918 model.
If you trip the circuit breaker off and leave for one minute before switching the power back on then hopefully the panel will be flashing, worked for me. Worth trying as replacement panel is not cheap, about $220 here in Canada.
TonyM
Mar 15, 2011 | GE Profile J2S968 Dual Fuel (Electric and...
GE profile JGSP44 Oven stopped working
Ignitor needs to be working for the gas valve to open. If the ignitor does not reach the proper amp draw the gas valve will not open. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing an amp draw test on the ignitor.
Mar 28, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile gas range
I would highly suggest using the filler strip or do not use the oven in self-cleaning mode. You may be able to get the one previously used with the oven if there was one.
Sep 08, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
154 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
