Question about Sony RM-952 Remote Control
Sony RM-952 remote control IR LED is not functioning.
I can not turn off the timer
Posted on Aug 10, 2011
I need a 3 digit cose to setup my CHUNGHOP RM-230E Universal DVD remote with my SANSUI DVD 3700S DVD player. I did follow the instuction and tried the codes supplied but the buttons are messed up for ex,...
1. There is no such thing as a 'universal' remote. 2. If the remote's design is earlier than the device you wish to control, no remote can be trusted to have the correct/full function code set for the newer device.
Since the manufacturers reinvent the code set for each new controlled device, the remotes become very quickly obsolete. Buying a 'learning' remote gives you at least some chance of using your newly acquired device with it after feeding it the codes from the original.
I downloaded the RM -230E manual while responding and I don't even see Sansui on the code list at all so they may have introduced their DVD player too recently for it to even be included in the code table of this remote.
I have the Chunghop RM-L988 and my orphan TV had to be programmed via IR but that works better than others I've had and this model has an 11 device capability. I'm only using it with three, two of which were contained in the factory tables, the third was done with the learning function. The only flaw I have found after two months of use, is the sloppy mounting of the IR LED which is pushed down onto the board inside and has to be aimed below the controlled device to work consistently. This versatile model has around 5,000 codes programmed and with the learning function won't become another 'for the drawer' for some time to come. Under $20.
This manual is from May of 2009 and may differ from yours but, as mentioned, no Sansui:
RM 230E manual link
Apr 27, 2011 | Televison & Video
My LG37LC2D-UD's remote control stopped working.I tested it on another exact same tv and it worked fine. That set's remote would not work my tv. I now know the ir receiver on my set is faulty. I found a...
For Eastern US customers, LG parts distributor is:
Vance Baldwin Electronics
1655 Lakes Parkway NW
Lawrenceville, GA 30043-5858
P (954) 723-9191 (800) 432-8542
F (678) 377-7599
You can also check if it is in-stock in this address:
9201 Penn Ave S.
Suite 40 Bloomington, MN 55431 Work (952) 881-6492 Toll Free (877) 881-6492 Fax (952) 884-5028
Jan 01, 2010 | LG 37LC2D Television
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Missing IR diode on RM-U800 remote
They should be all generic so find an old remote and scounce that for parts. Make sure you you get the polarity right or do it again with another IR LED as you might blow it is you place it wrong way.
Apr 02, 2009 | Sony RM-U800 Remote Control
Sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Feb 05, 2009 | Sony DAV-FR10W System
I just can't get it to work, new batteries and all.
First check if the remote control is sending an infrared signal. If the LED is flashing, this does not mean the Remote control is sending the IR signal. There is a separet Infrared LEd that sends the signal. To check the IR, point the remote control in a video camera or any camera with real-time monitor (phone cam, webcam, etc.) and press any button. You will see a white flash coming from the Remote control. thjis works best if the camera is black&white, for color camera, the IR is still visible but quite faint. Another way of checking the IR (if you do not have a camera) is to press the RM in front of another device with remote control and while doing so, press the correct remote control . If that other does not function or functions erratically, then the remote control in question is emitting an IR signal. If there is no IR coming out, the solder conection of the IR LED might be the problem. It is rare that the IR LED will be damage because the remote control is only 3 volts. If the remote control does emit an IR signal, then the TV remote reciever is defective. I had this problem with a CD player that I have fixed. The IR reciever looks like an LED (dark colored) with three pins (V+, signal, ground). Cost less than $3
May 18, 2007 | Jensen JER-323 Remote Control
Televison & Video Logo
123 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
