Question about Husqvarna Designer I
Husqvarna Viking Designer 1
Wifes sewing machine has stopped noting when the lower spool (bobbin) has run out of cotton. Is there a sensor or similar that requires cleaning ? Or worse!
  • tremble Jul 09, 2008
    Great. Thanks for the speedy reply
Remove bobbin case,clean sencers with a soft brush.At 10 o"clock and 5 O'clock positions approx.
Posted on Jul 08, 2008
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
I have the Husqvarna Viking designer ruby. It is making huge loops on the underneath side of the fabric. This is during straight stitch on cotton and then on duck cloth. I have cleaned underneath t
Typically, when there are loops on the bottom of the fabric, there is something missed in the upper threading. Make sure when threading:
- the presser foot is in the up position to open the tension disks
- make sure the thread is well "seated" in the tension disks before continuing to the take up bar.
- using the manual follow the thread path carefully
- check to make sure the thread flows smoothly from the spool
- use the correct size spool caps to help the thread flow easily
Dec 30, 2014 | Husqvarna Sewing Machines
Thread ball up
Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 24, 2009 | Husqvarna Designer I
Husqvarna viking designer 1 spool pin 412520901 and bobbin plate cover... I need the parts
Contact your local authorized Husqvarna Viking dealer. You can find a dealer closest to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us/ They should be able to order the parts for you. Also there are several third party websites with genuine husqvarna viking parts - http://www.Sewingpartsonline.com or http://www.pd60.net Good luck.
Jun 29, 2009 | Husqvarna Viking 1
Viking Designer SE missing the spool holder where can I buy one?
some authorized husqvarna viking dealers have websites where you can order the spool holder. Might just call an authorized dealer and purchase over the phone. Other 3rd party vendors are http://www.pd60.net and http://www.sewingpartsonline.com may have these. Hope this helps.
Mar 14, 2009 | Husqvarna Viking 1
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Oct 24, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
211 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
