Question about Amana ATB2136ARS 33" Top Freezer Refrigerator w/ 21 Cu. Ft. Capacity, Central Cool System & 4 Adjust...
Freezer temp seems to be fine but fresh food area not cold
  • 1,772 Answers
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Posted on Jan 01, 2011
Freezer working fine, fridge not at all
Brand name and model would help but here is a guess. Most frost free refrigerators have the main cooling unit in the freezer area side. To get the fresh food side cold, there is a small fan in the freezer side that blows cold air to the fresh food side through a duct work or trap door. If that fan stops or fails for and reason, the first place you will notice the temp rise is in the fresh food section. See if you can hear the freezer fan running. You may need to push in the door switch for the freezer light to hear the fan because they sometimes run the fan wiring through the door switch. It may stop when door is opened.
Apr 03, 2015 | Refrigerators
E402b freezing food
there is a little door between the freezer and the fresh food usually when that happens the motor on that door is bad and sticks open and allows the fresh food to get to cold since your freezer actually cools the fresh food side, sorry i cant tell you where it is on yours since they are are different, it will be where the cold air blows in the fresh food side and the part is not usually expensive and fairly easy to replace.
Mar 23, 2014 | Fisher and Paykel Active Smart E522B...
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Feb 19, 2010 | Refrigerators
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
The refridgerator is cool, but not cold.....of course the same for the freezer. the freezer is running, just nor getting cold enough. food is thawing and thermostat is reading almost 40 degress in both...
Je your defrost thermostat, heaters or timer is not working correctly or at all. The freezer has the coils that freeze the freezer and cools your fresh food area. When your defrost does not work these coils become blocked with ice and will not let air from fans pass through!!! Leaving a moderate temp in fresh food area.
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kemore brand - freezer works fine, refrigerator not cold,
The fresh food side is cooled by the freezer side through a duct between the two. It will have a small door that opens or closes depending on how cool you want the fresh food side. The door opens more as you adjust the temp for the fresh food side colder. If the duct is blocked in any way, then it would be like setting the temp setting for the fresh food side warmer and warmer. The freezer would be cold and the fresh food side would be warm. Set the temp to midway. Check for any obstructions to this duct. The evaporator fan is what moves the air to the fresh food side.. If the evaporator fan is not working, this could vary well is the problem. You may have to check the evaporator coil to see if it is frosted up enough to restrict air flow over the evaporator and to the fresh food side. If this helps you find your problem, please rate me. If there is anything else I can help you with, please ask. I am here to help you.
Nov 14, 2008 | Refrigerators
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana ATB2136ARS 33" Top Freezer Refrigerator w/ 21 Cu. Ft. Capacity, Central Cool System & 4 Adjust... Logo
56 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
