Question about Taylor 5596 Body Fat & Body Water Scale with Calorie Reference
How do I get a manuel for the taylor 5596 body fat scale
r321567499
  • 74 Answers
SOURCE: How do I get the detailed instruction manuel for the Taylor Bodyf
This link allows you to trouble shoot and download manuas directly with/from the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
  • 58 Answers
SOURCE: taylor scales model 7314 lithium scale
Have you tried to email Taylor Customer Help and Support?
They are very useful. They can guide you through problems, provide you with instructions and might send the user manual via email.
I hope you get this fixed. Scales are very tricky!
Posted on Oct 25, 2009
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
SOURCE: say it in English,not British
1. Turn the unit on.
2. At the same time, press and hold the "G" button and the power button.
3. While continuing to hold down the "G" button, release the power button.
4. Release the "G" button.
5. If you have done this correctly, the unit will power on. This procedure will switch back and forth between lbs. and kg.
Posted on Apr 25, 2010
jyackle5
  • 8197 Answers
SOURCE: Lost instructions
here is the owner manual from taylor http://personalcare.owneriq.net/mdownloads/500eae21-4ecd-4504-9c69-a27dc677644a.pdf
Posted on May 14, 2010
Testimonial: "Thank you, received the manual promptly, appreciate it."
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    Need # for replacement battery, please
    Many Taylor scales use one or two CR2025 or CR2032 batteties.
    I usually put in the higher current CR2032. These are available online, shopping centers, pharmacies, and even grocery stores. If you Google your part number and manufacture you can download the manuel which will tell you the battery required.
    May 09, 2016 | Taylor 7321 400 Pound Lithium Scale
    How do you calibrate, it's a body fat scale, can't find model #?
    It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
    If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
    Taylor USA FAQs Scales
    Searches related to Taylor body fat scale model number location
    taylor body fat scale model 5741 manual
    taylor body fat scale model 5761bf
    taylor body fat scale model 5731f reviews
    taylor body fat scale accuracy
    taylor body fat scale 5731 review
    taylor body fat scale athlete mode
    taylor body fat scale readings
    taylor body fat scale5758f manual
    Aug 01, 2014 | Taylor Health & Beauty
    I need a Taylor 5579 Body Composition Scale Manual
    Check under your scale, mine had the instructions listed there
    Feb 10, 2013 | Taylor 5568 Fat Scale Stainless Steel ()
    Where do I get a manual ?
    you can purchase a manual of Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale on ebay or in amazon...http://www0.dealtime.com/taylor-glass-body-fat-scale-manual/products
    Apr 27, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
    I need an instruction manual for my taylor body fat scale #5568.
    I posted the manual in my photobucket album here:
    http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
    Amy
    Nov 01, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
    Taylor scales model 7314 lithium scale instructions/manuel need
    Oct 25, 2009 | Taylor Health & Beauty
    Dec 01, 2008 | Taylor 5593 Body Fat/Body Water Scale
    Taylor 5596 Body Fat & Body Water Scale with Calorie Reference Logo
    54 people viewed this question
    Top Taylor Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
