Question about ViewSonic VX922 19" Monitor Flat Panel
Monitor does not turn on - plugged in - worked this morning
  • 6,771 Answers
This may sound silly check the wall receptical with a lamp to make sure you have power. I sometimes find that the plug in the monitor becomes loose, re-seat the plug. If all this fails I suggest a professional check out the device with a estimate.
Posted on Jan 01, 2011
My soyo television is hooked up to cable . the 2 other televisions in the house work fine. I turned it on theis morning and got a message "no signal"
Turn off the monitor,Unplug the power cord.Unplug the cables at both ends. If is plug in to a PC ,turn off the PC.Plug the cables back and plug the power.Turn on the PC.
Dec 19, 2010 | Soyo DYLM2286 Monitor
My computer screen wont come on when i turn the computer on
mine did the same thing this morning when I started it the monitor didn't work
I unplugged the power cord & plugged it back up & it started like it was suppose to
check all the cords on the back of the tower & make sure there plugged in correctly
if it still doesn't work, the monitor may have gone out
Nov 18, 2010 | Computers & Internet
Dead Monitor
check the plug at the back of the monitor. insert it properly
Aug 01, 2009 | Videoseven V7 L19PS 19" LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
My monitor will not turn on
Hi you didnt say whether you tried changing the plug fuse,try that,if it still doesnt work then the power cut you had might have been a power spike in which case the monitor would be destroyed.Try testing the fuse in the plug first ..ok.
Dec 29, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
I have to heat up my CRT
it is a weak cathode heater inside the CRT. One fix, besides what you are doing, is to replace the glass tube (crt) inside the monitor. Unless you can find a used one, may be hard to find now. It may also be possible to supply the heater filament with a separate supply. I believe this requires a 6 volt supply, so try adding a 10 volt (FUSED- 2 amp) supply to the filament only.
Nov 20, 2007 | Computers & Internet
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
No Power
There is a whole lot the typical user can check but here is the list: -Disconnect the power plug from the power strip and plug directly into a tested wall socket. Sometimes the power strip sockets go bad. -Try another working power cord. -When you plug in the power cord do any of the monitor LEDs com on?
Jul 29, 2007 | HP vs19 (Silver) 19" LCD Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
22 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
