I'm trying to reset my dir-632 to factory state but after holding the reset button down for 10 seconds the wlan light flashes and keeps flashing, shouldn't it stop so it resets. I'm doing this because the setup is telling me to change user name and password.
3 Suggested Answers
  • 33 Answers
SOURCE: D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
Posted on Mar 17, 2009
  • 731 Answers
SOURCE: How do I restore the router back to it's factory
Press and hold the Default reset button on the rear panel until the power light blinks... about 10 seconds
Release the button and wait for the router to reboot
Posted on Jan 04, 2011
Both lights on my older model machine won't stop flashing
Try holding both buttons down while you turn on the machine - hold down till they stop flashing, usually 2 - 5 seconds. This resets the machine to its original factory settings.
Oct 11, 2014 | Nespresso Coffee Makers & Espresso...
Link failed and flashing light
      it sounds like you have locked the Router into Firmware Flash mode by incorrectly performing the reset steps which are :
      To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a
      paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
      Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
      If however, one presses and holds the Reset button while it's off, then turns it ON, then it will start the flash process and flash the power light orange.
      To recover, you will need to re-flash the Router.
      Here is the D-link support page to find your firmware, you will need to find the correct "version" of the 615 you have and download that file, (you will need to un-zip it,) then follow these steps :
        1. Disconnect the power cable from the router.
        2. Open a web browser and type in the URL http://192.168.0.1/ but DO NOT PRESS [enter] or the [GO] button yet.
        3. Press and HOLD the [reset] button on the router and connect the power cable. Continue to hold the [reset] button for about 10 seconds, then release.
        4. Now click inside the address bar of the browser and press [enter] or the [GO]. The "Emergency Room" Updating Firmware screen should display.
        5. Browse to and upload the DIR615_v4.11_B02.bin image file.
        6. When you see the message "IMAGE UPLOAD SUCCESS", the flash will begin to be erased and re-written.
        7. Use your browser to again connect to the router at http://192.168.0.1/ or press [F5] and refresh the page.
        The Dlink setup screen should load. If not, you did something wrong. Go back and try again.
Aug 31, 2012 | D-Link DIR-615 Wireless Router
Hello, my password and username for the Router
how the button in again for 5 - 10 sec's until all the led lights start blinking.
the default login/pass
should be
admin/admin or admin/blank
Mar 09, 2011 | D-Link DIR-615 Wireless Router
I have a problem flashing button to start the router and not starting. how to solve?
Perform a D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
When I plug in the router, the power light comes on steadily, and four other lights are flashing. The light that looks like a globe, and the lights shaped like computers numbered 1-4 all start flashing. ...
On page 6 of the DIR-600 user manual, try pressing and holding the reset button for 30 seconds using the tip of a ballpoint pen to factory reset the router.
If that does not resolve the issue, then most likely your router has failed and will need to be replaced. This DIR-600 router became End Of Serviceable Life on December 1, 2009.
Dec 21, 2010 | D-Link DIR-600 Router
How do i reset my d-link dir-615 to factory settings
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link DIR-615 Wireless Router
Dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
May 22, 2010 | D-Link DIR-300 Wireless Router
I need to reset my new D-Link router to the
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get instant online router/wireless router support at http://www.vtechsquad.com/wireless-router-support/ to fix D-Link router/wireless router issues.
Jan 02, 2010 | D-Link DIR-615 Wireless Router
DLINK ROUTER DI-624M
Press the reset button on the back of the router and hold for 10-15 seconds, this resets router to factory defaults. Access the router using the IP address of the router http://192.168.1.1 access the router setup and create your PPPOE internet connection provided by your ISP using your username and password connect to the router via the computer. BPCS
Dec 29, 2007 | D-Link DI-624M Router (DI624MRE)
Reset to factory settings??
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
1,522 people viewed this question
David Payne
David Payne
