Question about Brother HL 5250DN Laser Printer
Had a power outage for several hours. Power came back on but the printer came on with all lights blinking. Turned power off and back on but the same problem. What's happened, and what do I do?
  • Brother Master
  • 5,568 Answers
Nearly all later printers have circuits that stay 'alive' even with the power turned off. Try pulling the AC plug overnight' this should clear most stored errors that may still be present.
Posted on Jan 01, 2011
After power outage front display blinking "16".
I had a similar issue where after a power outage, the player would not power up.
I removed it from power and took the cover off looking for a fuse. Could not find anything so I put the cover back on and plugged it in and it worked. My theory is the electronics needed time to fully discharge in the circuits. I would leave it unplugged for about 24 hours. I left mine unplugged for several days. I hope this helps.
Feb 13, 2016 | Toshiba SD-3990 DVD Player
Epson wf-7520 power light, auto answer light & wi-fi light blink
As far as the wifi is concerned, try getting it connected to your home network. Once it gets connected, go into your network settings and try to get the IP address. If you can obtain that, you should be able to add a network printer using TCP/IP port. Also, see if you can factory reset the printer, and start the setup all over.
Feb 17, 2014 | Epson WorkForce WF-7520 Wide Format...
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
Samsung RF26X series refrigerator. Power Co turned off our power to do some work in our neighborhood. Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes 88 then...
This is normal after power outage .
Unplug for 30 seconds to clear code then wait several hours for computer to stabilize.Then your good to go.
Was this helpful?
Aug 16, 2011 | Refrigerators
We had a power outage now the T.V. won't turn back on, there are no lights on or blinking. I can't get it to show any signs of life. What's the deal please help!
Unplug the set for 2 hours then plug it back in. After a power outage when the power returns it will sometimes send tvs into a dumb mode, unpluging will reset the tv to factory settings and it should run just fine
Jan 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
HL-1440 We had an unexpected power outage and now the drum light blinks then all 4 lights blink. I try to push the reset button and nothing. It was working fine prior to the outage. It it just a local...
Try this solution.
* Turn your printer off.
* Hold in the circular button on the front panel of your printer.
* Turn your printer back on.
* When the drum light is lit by itself let go of the button.
* Hold in the circular button on the front panel again.
Once the Alarm light comes on, let go of the button.
Your printer should now be reset.
Hope this help you.
Aug 03, 2010 | Brother Office Equipment & Supplies
After a power outage my wd62525 won't restart.......the green timer light has been blinking for more than 24 hours HELP!! (I did try to reset, same blinking)
There is chance that the power outage might have damaged the power supply. It does happen, it's most common with storms. I recommend that you go to a shop and get that board checked
Dec 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My 2002 ws55511 during a power outage turned off and will not turn back on, i have tried to diconnect tv for several hours and up to several days and plug back in, green light blinks for 30 seconds or so...
This same problem happened to my 55511 about two years ago. It appears to be a software issue. I ran the built in self test and it corrected the problem. Have you tried this?
May 06, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
Brother HL 5250DN Laser Printer Logo
253 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
