Question about Microsoft Windows XP Professional
Hi! I own a Seagate Free Agent Go 320GB(Flash Memory). I can't see any files or folders in my drive(Here i.e I:). But when I checked the properties of the drive it showed me 99GB free out of 298GB. I tried registry edit to make all folders visible it worked for other drives but didn't work here. But one thing seems to be working. eg: If type " I:\movies " the folder opens and I can see the files and folders in it and I can open and watch the movies... But I forgot the name of some important folders and the windows search option doesn't work Please help me out of this... Thank you :)
  • Raghavendra Kamath Jan 01, 2011
    Sorry but I dint get you..I'm using this drive for the past 6 months or so..Actually it was normal about an hour ago...
    Problem Solver:
  • 17 Answers
There is a login that needs to be done on this drive with the software included with the drive before you can see the files, they are hidden until you unlock the drive
Posted on Jan 01, 2011
  • 2 more comments
  • 88twincubes Jan 01, 2011
    Have you tried to clean all temps files and reboot the machine, This simply sounds like a view is just hung up.
  • Raghavendra Kamath Jan 16, 2011
  • 88twincubes Jan 17, 2011
    Please discussion lay out your issues in detail. Copying your base issue with no details will not help
MY SEAGATE (FREE AGENT), WILL NOT OPEN BECAUSE IT SAYS THE FILE OR DIRECTORY PATH IS CORRUPTED. HOW CAN I FIX THIS.
First run check disk on the drive [chkdsk] [Drive Letter] from a command prompt2_bing.gif. It sounds like you have a bad sector on the drive.
When that is completed run defrag on the drive
Let me know when completed - we can take it from there
Jan 07, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
How do I transfer files to my seagate free agent?
Just left-click the file or folder you want to copy, choose copy.
Open My Computer and find the external drive, double click, once the folder opens just right-click and choose Paste.
That's pretty much it....or you could also drag files / folders to the drive.
Hope this helps.
Nov 24, 2009 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Sep 17, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate Free Agent Go Problem
Install the seagate manager on a different computer and decrypt the files there first then move it back to your computer using the basic copy/cut and paste.
May 27, 2009 | Seagate FreeAgent Pro 500GB External USB...
Seagate free agent 1.5 terabyte will not stay connected to my computer When I connect my free agent to my computer (Asus laptop with Vista Home premium) all the folders show up and I can access files for...
Check the HDD on a different USB port. It there is still problem, try that with a different computer. If it still shows this issue, try changing the USB cable. If the issue persist, its your HDD.
Jun 06, 2017 | Seagate Free Agent Go Small 12 GB USB...
Problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=174395
Jan 24, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
My seagate free Agent exturnal hard drive
Hi, Sorry to hear you are having problems,
When you open your hard drive, is it locked ? Do you see a pencil with a line through it in the bottom left had corner ?
It could be that the drive has inproper permissions....
So, try this, click on the Hard drive icon (Please be sure it is the external drive, NOT YOUR STARTUP DISK ) then get info on the drive. In this info window, at the very bottom, you should see a check box allowing for: ignore ownership on this volume. Please click this box.
Now, try creating folders on the drive...
If this does not work, I highly recommend reformatting this Hard Drive, that is assuming there is no valuable information on it.
After reformatting it, it really should work porperly.
Dec 16, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
FREE AGENT 250 DESKTOP
ok, well the 0x80070057 error code typically occurs because of 3rd party driver issue!
so, this is long but a program that fixed this was removed (sad)
rename the "SoftwareDistribution" folder:
Click Start, Choose Run.
In the Run box, type: services.msc
Click OK.
Right-click the Automatic Updates service.
Click Stop.
Stopping the service will take a moment.
Now rename the "SoftwareDistribution" folder:
a) Click Start, click Run, type
%systemroot%
...and then click OK.
b) Right-click the SoftwareDistribution folder, and then click Rename.
c) Type SoftwareDistribution.old and then press ENTER to rename this folder.
Now click Start, and choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
NB - You will lose your update download history but this is not that important really being a fresh comp!
good luck! lamby
Jan 30, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Microsoft Windows XP Professional Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
