Question about Samsung DualView TL205 Digital Camera
My samsung tl205 has a black screen and the lens is jammmed and won't open or close it's just stuck when you hit the power button a green light comes on and blinks.
SOURCE: Kodak Easy Share Z1275 stuck lens
I have the same problem with my z1275. If your camera's on warranty, don't fool around.
I just went to the Kodak web site, filled out a form, quickly got an email reply with painless instructions of where and how to mail the camera. They mention a 2 week turn around from the time they receive the camera - not bad.
Posted on Jun 21, 2008
SOURCE: Camera will not turn on sucessfully. Says "Turn Off and On Again"
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Posted on Mar 26, 2009
  • 148 Answers
SOURCE: samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Posted on Apr 02, 2009
  • 502 Answers
SOURCE: lens stuck in the extended position
i don't think the lens mechanism can be repaired, it may need to be replaced, usually for about 50% of what you bought the camera for. there is a company in new york that carries parts for small digital consumer cameras like this : Camera Repair NYC
Posted on Apr 28, 2009
  • 17 Answers
SOURCE: my samsung l830 camera lens is stuck open and when
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Posted on Aug 01, 2009
Samsung TL205 Camera turns on but the screen never shows any sign of light. Screen is not able to display anything. Can this model be reset?
Many times you can turn the screen off in the menu up settings. Some cameras have a physical button on the camera to do so. Look your camera over carefully, and read the menu settings in your manual. If you don't have that, scroll through all your settings and see if you've turned off the LCD.
Oct 13, 2014 | Samsung DualView TL205 Digital Camera
Lens stuck
Please see this link for troubleshooting steps for a stuck lens.
And here's a video summary of the steps.
Apr 28, 2013 | Samsung S860 Digital Camera
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
My new camera (samsung TL205) will not turn on, when i press the power button I hear a chiming sound but the camera will not power on.
mine is doing the same thing. but my lense wont even close. and when i press the button to power on the green light comes on then beeps, then goes off. so if you get a word on how to fix it let me know.
River
Dec 24, 2010 | Samsung DualView TL220 Digital Camera
Last week I was taking pictures outdoors, later on that day my screen went totally black, the green light comes on but the screen continues to stay black, I have changed the batteries
One of three possible problems. First check that you didn't accidentally press the DISP or DISPLAY button. If that's not the problem...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Finally, it could be a loose or poor connection of the screen's flex cables, a very common problem for your model camera. The A620's vari-angle screen is a great option for a camera, but with this moveable screen, the screens data and power cables can and do wiggle loose. It is actually relatively easy to fix by just reseating these cables, but will require opening the back face of the screen of your camera.Please see this other person who had a similar problem with an A630.
May 05, 2010 | Canon PowerShot A620 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung DualView TL205 Digital Camera Logo
250 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
