Question about Acer Aspire 9300 Notebook
When I power up my Aspire 9300 it gives me 1 long and 2 short beeps, nothing appears on the screen. every once in a while Windows will appear as if it loading, then it stops and goes blank. Also if I leave it on after the beeps the fan starts making quite a noise. Thank you, George tedtednow@yahoo.com
  • 20 Answers
Hi. First take all the removable panels off the bottom of the laptop. Remove the RAM, wireless card, HDD, DVD drives. Remove the battery and mains power supply. The DVD drive will have a locking screw at it's back end on the base of the machine, carefully pull the drive out when released with it fully open so as not to break the front plastic cover. Open it manually with a paperclip end pushed in the hole on the front cover if necessary.
Now press and hold the power on button for about 1 minute. Reconnect a fully charged battery or the mains power supply and see if the machine starts. It will probably complain of no RAM and failed HDD but don't worry if it does. Now power down and refit the RAM. Power up again. The board should post and report failed HDD. If not one strip of ram may be faulty, try one at a time to isolate the bad one. If ok power off and refit the HDD. If all is ok, refit the remaining parts one by one powering off in between. If your motherboard is working it may come back to life this way and you have found the faulty part in the process. If all this fails and you have 2 flashes from the HDD light and a stable power light and or the main power button light comes on as soon as power is applied without pressing it then you likely have a faulty motherboard. On a final note for the above fault, total failure of the motherboard can occur when intermittent starting happens if the CPU fan is totally blocked by dust. This causes the entire machine to run too hot. A thick layer of dust is deposited over time on the INSIDE of the heatsink vane pack. It creates a total blockage to the airflow. It can be removed by opening the machine and cleaning manually or it can be extracted from the fan port with a vacuum cleaner (where you can see the fan blades on the bottom) Large lumps of dust can block the fan while doing this so a thin wire to pull dust clumps through the grille can be handy. Make sure all the dust is removed and the fan rotates freely before using the machine again. The symptom to this is very fast fan all the time instead of varying speed according to overall temperature and CPU workload.
Phew! Hope this hepls
Steve at Olive Country Computers in Spain
Posted on Feb 15, 2011
Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Sep 26, 2012 | Acer Aspire 9300 Notebook
My acer aspire 9300 have beep code: 1 long and 2 short in start up..
This beep code is -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
This is most likely a video problem.
Try re-seating the RAM, the video RAM is shared, uses part of the main RAM.
Also try restoring the BIOS setting back to the default settings.
Mar 03, 2011 | Acer Aspire 9300 Notebook
Hello, I have ACER ASPIRE 9300 and my screnn is black. When I turn on, nothing happens... no beeps, nothing. what can I do? Thanks, Paula
If you view the screen at a sharp angle after the computer has booted up and you see a dim Windows image, then you have a backlight problem. This problem could be caused by a faulty inverter board which supplies high voltage to the CCFL lamp or the CCFL lamp could be faulty.
Replace parts are available from www.lcdparts.net
Sep 05, 2010 | Acer Aspire 9300-3716 Notebook
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
LCD NOT APPEAR
Bios does one long and two short beeps
This is the code for Video Failure.
Replace the Vid Card.
Sep 04, 2009 | Computers & Internet
One long and two short beeps while starting
hi
this may be ur ram problem so get the ram of more memory
Jun 25, 2009 | Acer Aspire 9300 Notebook
Acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Jun 21, 2009 | Acer Aspire 9300 Notebook
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
Feb 18, 2009 | Acer Aspire 9300 Notebook
Screen won't appear upon start up and I get 3 beeps but no screen
what you are hearing is a beep code, if its 3 short beeps then its the memory which has developed a fault and it may need to be replaced
Nov 16, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 9300 Notebook Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
