Question about Broan-NuTone Allure® I WS136BC Kitchen Hood
Broan QS1 hood, Fan works but lights won't come on. One light blew and when I replaced it, neither one worked.
5 Suggested Answers
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
  • 1462 Answers
SOURCE: Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Posted on Mar 31, 2007
SOURCE: Ventline Range Hood Fan broken
In my RV, which should be similar, I removed the filter from the hood. With power off, I removed the fan, which was held on with a clip. Removed two screws holding the motor in and took it to a camper supply store. Mobile home supply would have had it, too. You might find the motor on line if you go to the website of the manufacturer or search for parts for that brand.
Posted on Sep 02, 2009
SOURCE: a bulb blew in my tecnik cooker hood and neither
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Posted on Dec 20, 2010
Lights quit working on broad range hood
The tiny metal tabs that contact the very end of the light bulb after it is screwed in making a circuit get pushed back too far when you tighten the bulb and with all the steam and muck eventually fail to make contact. shut down the power and use a tiny screwdriver to gently nudge the electrical contacts back up "a little cleaning wouldn't hurt either" look at the very bottom of your bulb, clean that too perhaps with a few strokes of a wire brush, gently put the bulb back in and you are good to go, mine did the same thing.
Mar 29, 2014 | Broan QS130WW Under Cabinet QS1 Series...
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Broan Allure II
I called Broan technical support. They said that they had heard of this issue before, but that there was no recall. I suggested that it was a frequent enough problem for it to come up 3 times in 12 mo. on one website. She was underimpressed with this statistic and said that they sell millions of them. She would not disclose the name of their supplier so that I could get some information on the actual controller unit. She did not seemed as pained as I was by having to part with $130 for a new controller.
Jan 30, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone Allure® I WS136BC Kitchen Hood Logo
369 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
