Question about Philips Magnavox DVD/VCR Dual Player
Have an older model Magnavox VCR. Having problems adjusting date to read "11" Only numbers in year column allowed are in the "00" to "10" range. Thoughts?
    President:
  • 1,140 Answers
I suspect that Philips/Magnovox did not expect anyone to still be using this VCR beyond 2010 - or, more accurately, did not expect that it would still be working. Many AV devices are only expected to last for 5-10 years before they either fail or become obsolete. Many die or are replaced/upgraded long before this time, but a certain number continue to function - and continue to be used - well beyond the manufacturers expectations.
I suspect this may be the case with your VCR. If you can let me know the model number, I can either verify this is the case - or hopefully tell you how it can be set to "11". It's very difficult to give accurate information without a model number or any idea of the age of the VCR.
Thanks,
BElectric
Posted on Jan 02, 2011
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
Tip
Nokia Secret Universal Codes
<p><span><span>Code Description :</span></span><span><br /> <span>These Nokia codes will work on most Nokia Mobile Phones</span><br /> <span>(1) *3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound</span><br /> <span>quality but talk time is reduced by approx. 5%</span><br /> <span>(2) #3370# Deactivate Enhanced Full Rate Codec (EFR) OR *3370# ( Favourite )</span><br /> <span>(3) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you</span><br /> <span>should gain approx 30% more Talk Time.</span><br /> <span>(4) *#4720#</span><span> </span><span>Deactivate</span><span> </span><span>Half Rate Codec.</span><br /> <span>5) *#0000# Displays your phones software version, 1st Line : Software Version, 2nd</span><br /> <span>Line : Software Release Date, 3rd Line : Compression Type. ( Favourite )</span><br /> <span>(6) *#9999# Phones software version if *#0000# does not work.</span><br /> <span>(7) *#06# For checking the International Mobile Equipment Identity (IMEI Number).</span><br /> <span>( Favourite )</span><br /> <span>(8) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w"</span><br /> <span>and "+" symbols).</span><br /> <span>(9) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w"</span><br /> <span>and "+" symbols).</span><br /> <span>(10) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w"</span><br /> <span>and "+" symbols).</span><br /> <span>(11) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w"</span><br /> <span>and "+" symbols).</span><br /> <span>(12) *#147# (vodafone) this lets you know who called you last.</span><br /> <span>(13) *#1471# Last call (Only vodofone).</span><br /> <span>(14) *#21# Allows you to check the number that "All Calls" are diverted to</span><br /> <span>(15) *#2640# Displays security code in use.</span><br /> <span>(16) *#30# Lets you see the private number.</span><br /> <span>(17) *#43# Allows you to check the "Call Waiting" status of your phone.</span><br /> <span>(18) *#61# Allows you to check the number that "On No Reply" calls are diverted to.</span><br /> <span>(19) *#62# Allows you to check the number that "Divert If Unreachable (no service)"</span><br /> <span>calls are diverted to.</span><br /> <span>(20) *#67# Allows you to check the number that "On Busy Calls" are diverted to.</span><br /> <span>(21) *#67705646# Removes operator logo on 3310 & 3330.</span><br /> <span>(22) *#73# Reset phone timers and game scores.</span><br /> <span>(23) *#746025625# Displays the SIM Clock status, if your phone supports this power</span><br /> <span>saving feature "SIM Clock Stop Allowed", it means you will get the best standby time</span><br /> <span>possible.</span><br /> <span>24) *#7760# Manufactures code.</span><br /> <span>(25) *#7780# Restore factory settings.</span><br /> <span>26) *#8110# Software version for the nokia 8110.</span><br /> <span>(27) *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date</span></span><span></span><br />
on May 15, 2011 | Cell Phones
A-TR on screen
The VCR is having trouble with tape tracking. You should have a tracking adjustment on your VCR
Sep 28, 2012 | Aiwa HV-DH1 DVD Player / VCR Combo
Magnavox NE206UD TV/VCR/DVD Combo Remote Control wat universal remote will work for it im trying to get my menu channel on for cable
There is no such thing as a 'universal remote' since the coding is totally non-standard and may differ from one model to the next even within one manufacturer's current lineup.
You may be able to find a listing of models for a given remote here:
Remotes
When thinking about buying a 'universal' remote, get the model number and check the maker's website for a listing of models the remote can control.
A "learning" remote that can accept commands from originals, as well as having a large number of code sets (thousands) that we have owned for ~ a year has been very satisfactory and at a bargain price:
Chunghop Remote
Shipping is free but from China so count on 10-14 days delivery.
Finally, if the remote is older than the set you want to control, it probably won't have the necessary codes to control all of the device's functions if any at all.
Nov 14, 2011 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
Im having trouble with the spreadsheet adding up the total of the numbers it comes up with " Value#" all the time and this can not be changed.
It just means that the column is not big enough to fit the full number in. Just widen your column and it should dissapear
Mar 23, 2011 | Palo Alto Business Plan Pro 11 Full...
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Magnavox VCR U095 39760450-can not put in 2009 YR to record
I called Magavox and Matt told me they had no information for my very very old vcr. He suggested that I trick the machine and use a date similar to the current calendar. For instance, today is Monday, January 5th. I went back to 2004 and found the same day and date. I programmed my vcr for 30 minutes to test it out and it worked. If you can't beat it, join it. Hope your vcr works too. Happy new year!
Ilene
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox 20" tv with vcr and dvd, Model #CT202MW8
call comcast they should know the correct code its there unit.
Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Philips Magnavox DVD/VCR Dual Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
