Question about Combi Centre DX - Mango
Ariston microgenus 27 pressure on 0
Need help lone female, boiler pressure showing zero know technician in the past has turned a knob think its the one on far left and pressure increased to make system more effective can you help???
Filling loop is underneath the boiler, easily identified as a chrome coloured braided pipe with a black tap at either end. Open right hand tap first then left hand one . Fill system till presure gauge reads just over 1 bar when system is cold. Then turn both taps off.
Posted on Aug 16, 2008
Sorry Terry - I'm not used to this site! Question was - anyone know what the error message E34 means on an Ariston Boiler MicroGenus 24HE please?
The information I have found states it is a problem with the pressure switch. A faulty pressure switch will prevent ignition from occurring. Here is a Youtube video link showing the issue. Reading the comments below may assist you in isolating your problem. Hope this helps!
Ariston microGENUS 24 HE MFFI Error 34
Oct 21, 2015 | Washing Machines
Ariston microgenus he24 fault is e34 but boiler works when front cover is removed
e34 on a ariston is the fan. Boiler fires up with cover off as its getting the air it needs from atmosphere! fan is not running at full speed
Nov 04, 2011 | Combi Centre DX - Mango
Ariston Gas Boiler error code E02 what is the problem. No other boiler specification on the type of boiler.
i belive you have a ariston microgenus 2,from memory thats the fault code for low water presure,you need to re-presurise to 1 bar
Nov 27, 2009 | Ariston Technologies AWD 121
Ariston Microgenus 27 boiler - leaking motorised valve
The leak is coming from a seal around the pin that the motor acts upon, the seal does not come as a replaceable part on its own, so the whole flow group as it is called will need to be replaced, approximate price 170 to 200 pounds inc vat, makers part no 998613. plus 2 or 3 hours labour of a corgi registered engineer. If your boiler is more than 6 years old and you have not had to replace the fan or other parts yet, then think about getting a new high efficiency boiler, it could be a better long term solution.
Feb 15, 2009 | Combi Centre DX - Mango
MicroGenus27 No Hot Water
check HW and CH temperature probes check secondary heat exchanger for blockage check water pressure switch
Jan 03, 2009 | Combi Centre DX - Mango
Boiler flames extinguish and reignite regularly
what about flame rectification probe (flame proving probe)
Nov 30, 2008 | Combi Centre DX - Mango
Ariston Microgenus 27mffi combi boiler
im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Aug 29, 2008 | Combi Centre DX - Mango
Pressure of Ariston Microporus 27 MFFI
the boiler reqs to be pressurised to 1 bar in a cold state, in operation the heat expansion with cause the gauge to rise by about half a bar so in full working mode with heating on you'll expext the gauge to register around 1 1/2 bar-
Jun 14, 2008 | Combi Centre DX - Mango
I have an Ariston Microgenus 27 Combi Boiler
I hate these boilers!
If the pump is not circulating change it. If the pump is ok you may have a blockage in the diverter valve
Apr 04, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
726 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
